Ordinate Dimension Set Not following View Scale and Crashes Inventor when Changing JogPoints
BrandonBibelhauser
BrandonBibelhauser
Utilizing VBA, I am changing the View Scale of an Elevation with success.  However, the distance of the ordinate dimension set (Text, jogpointone, jogpointtwo) to the view does not remain the same distance.  There are 4 ordinate dimension sets in my view and the top ordinate dimension set is the only one with the issue.
Is there a setting I missed when creating the ordinate dimension set to prevent this issue?
I've attempted to shift the ordinate dimension set (Move Ordinate Dimension text) after the View Scale change but Inventor crashes.  I believe this is related to ordinate dimension sets because I was successful at shifting just an ordinate dimension.
BrandonBibelhauser
Update: The crashing while shifting ordinate dimension sets via jog points has been resolved by updating my Inventor release to 2021.5.2.
Why 3 of the 4 ordinate dimension sets properly scale with the drawing is still a mystery.
