ILogic error
ILogic error
gaexcalibur
ILogic error
gaexcalibur
I am very new to Ilogic and Inventor as a whole.  I have created some simple parts and pieces that have Ilogic attached.  the program and form for this object work just fine right now but when I try to put it into a different assembly I get this message.
error on line 1 in rule: corner angle , in document:fe90-02iam
parameter: the component named "fe90 part2:1" was not found.
This happens every time I try to add an iLogic part or assembly to a different one. Please help this is driving me nuts.
Thank you all
A.Acheson
Hi @gaexcalibur
I cant open that file so if you can provide the  code and the error messages and a screenshot of the browser pane where it is not working. Is the error occurring in the assembly you are copying? Also check any file path of parts to ensure they have a fullfilepath if the origional location is not inside the project folder.
This could also be the occurrence name not being stabilized in the assembly. When you change files then the  code is reading the old name and not a consistent name. See this help article here
Regards
Alan
