Open .iam in project folder ilogic?
DeerSpotter
Message 1 of 22
DeerSpotter
instead of this can i actually have it look at current project folder?
'these links will need to be updated for current physical location everytime folder is moved or renamed.
Public Sub Main()
If Component.IsActive("DETAIL B 26310C:1") Then
ThisApplication.Documents.Open("G:\FEA\Baseline\shell outer _ 26310c rev - (Ilogic)\DETAIL B 26310C.iam", True)
End If
If Component.IsActive("DETAIL B 26310C REV1:1") Then
ThisApplication.Documents.Open("G:\FEA\Baseline\shell outer _ 26310c rev - (Ilogic)\DETAIL B 26310C REV1.iam", True)
End If
If Component.IsActive("DETAIL B 26310C REV2:1") Then
ThisApplication.Documents.Open("G:\FEA\Baseline\shell outer _ 26310c rev - (Ilogic)\DETAIL B 26310C REV2.iam", True)
End If
 End Sub
 Any help would help out alot.... thanks!
Image and video hosting by TinyPic
See My LinkedIn Profile
Replies (21)
Message 2 of 22
mrattray
I'm not sure if you can (or I just don't know how) to look at the project file data, however, I know we can get the file path of our current document. Would this work for you? Does the folder you're moving contain the document which this rule fires from?
Mike (not Matt) Rattray
Message 3 of 22
DeerSpotter
Yes Getting the File Path of the Current Assembly would be good enough. Thing is that those assemblies are actually in a subassembly.
Could we just somehow eliminate the G:/ instead just have last folder location? or something similar... whatever would work.
Message 4 of 22
mrattray
You can use this to get the path of the current document:
ThisDoc.Path
Or, while I was double checkling that function, I noticed this:
ThisDoc.WorkspacePath()
One of these should work for you.
Message 5 of 22
DeerSpotter
trying to solve this equation im still getting errors would you be able to help me?
you can see that by specifing full path it opens it, but by trying to do the code trick it always errors out. even if i use
Any ideas?
'ThisApplication.Documents.Open("G:\FEA\Baseline\shell outer _ 26310c rev - (Ilogic)\DETAIL B 26310C.iam", True)
ThisApplication.Documents.Open(ThisDoc.Path("DETAIL B 26310C.iam"), True)
'ThisApplication.Documents.Open(Component.IsActive(MakePath("DETAIL B 26310C.iam")))
End If
Message 6 of 22
DeerSpotter
i also went as far as this to try to open the document...:/ same error
'define the active document
oDoc = ThisDoc.Document
'create a file dialog box
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
'check file type and set dialog filter
If oDoc.DocumentType = kPartDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt"
Else If oDoc.DocumentType = kAssemblyDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam"
Else If oDoc.DocumentType = kDrawingDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw"
End If
'Set the directory To open the dialog at
oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
'set the file name string to use in the input box
oFileDlg.FileName = ("DETAIL B 26310C.iam")
ThisApplication.Documents.Open(oFileDlg.InitialDirectory(oFileDlg.FileName))
End If
 I'm completely lost...
Message 7 of 22
rjay75
The WorkspacePath, InitialDirectory, Path are all string variables, not functions. To append them to your file name you need to do this.
Dim fullName As String
fullName = ThisDoc.WorkspacePath & "\" & "DETAIL B 26310C:1"
 Also if you have any more directories after the path you have to include them as well.
Message 8 of 22
DeerSpotter
could you show me how to use that with?
ThisApplication.Documents.Open()
Message 9 of 22
rjay75
Assuming you have the file in the root directory of the workspace path:
fullName = ThisDoc.WorkspacePath & "\" & "DETAIL B 26310C.iam"
ThisApplication.Documents.Open(fullName)
Message 10 of 22
DeerSpotter
why doesnt this work? Grrrrr
Public Sub Main()
Dim fullName1 As String
fullName1 = ThisDoc.WorkspacePath & "\" & "DETAIL B 26310C:1"
ThisApplication.Documents.Open(fullname1, True)
End If
End Sub
 welp.... 😞
Message 11 of 22
rjay75
If the location of the assembly and the components are in the same folder then you can do this.
fullName1 = ThisDoc.Path & "\" & "DETAIL B 26310C.iam"
ThisApplication.Documents.Open(fullName1, True)
 ThisDoc.Path is the location of the file running the rule.
ThisDoc.WorkspacePath is the root workspace folder.
If you want to see what they are create a rule and add this:
MessageBox.Show("Doc Path: " & ThisDoc.Path & VbCrLf & "Workspace Path: " & ThisDoc.WorkspacePath)
 This will help you to see which path you want to use. You a have to add any missing sub directories between the path and the file name.
So if your ThisDoc.WorkspacePath equals "G:\FEA\Baseline" and then it would be
Dim fullName as String
fullName = ThisDoc.WorkspacePath & "\shell outer _ 26310c rev - (Ilogic)\DETAIL B 26310C.iam"
ThisApplicationDocuments.Open(fullName, True)
 If your ThisDoc.Path equals "G:\FEA\Baseline\shell outer _ 26310c rev - (Ilogic)"
fullName = ThisDoc.Path & "\DETAIL B 26310C.iam"
Message 12 of 22
DeerSpotter
this part worked for me! You just saved me hours of research!
Thanks!
Message 13 of 22
DeerSpotter
Okay now to compound on this resolved issue. (i feel this thread is going to be viewed by a great many).
What kind of ILogic Code can i use to instead of opening something up; but editing it in place?
Any ideas?
Please let me know 🙂
Message 14 of 22
rjay75
You can activate the edit of a component from iLogic. But only one component in an assembly at a time.
'Start The edit of a component
Component.InventorComponent("DETAIL B 26310C REV2:1").Edit()
'End the edit of a component
Component.InventorComponent("DETAIL B 26310C REV2:1").ExitEdit()
Message 15 of 22
DeerSpotter
exit edit is not working.... is there any more of a generic type of exit edit?
EditExit () seems to work slightly, but it cant find component.
Message 16 of 22
rjay75
Are you calling it from a rule in the assembly or component.
To use it that way it needs to be called from the assembly. (And I missed a parameter for it too.)
Component.InventorComponent("DETAIL B 26310C REV2:1").ExitEdit(kExitToPrevious)
Message 17 of 22
DeerSpotter
This Right here Works:
Public Sub Main()
Component.InventorComponent("shell outer _ 26310c rev -:1").Edit()
End If
End If
End If
End Sub
 But when i create a rule in the Subassembly that it is editing like so, it cant find component. But if i create the rule in the original assembly and run it through a form it gives me a hresult:
Public Sub Main()
Component.InventorComponent("shell outer _ 26310c rev -:1").ExitEdit(kExitToPrevious)
End If
End If
End If
End Sub
Message 18 of 22
rjay75
The reason it doesn't work while it's editing a component is the component by name only exists in the assembly. Whenever a component function is run the function searches the file that owns the rule for that component name. So if the file is not an assembly and if it is but doesn't internally have a component of that name the rule won't work.
Doing it from the assembly is the correct way.
One note if you want only one of these to be able to edited when the rule is run, modify your IF blocks. Theorectically if two of your components are active it can try and edit both at the same time.
Public Sub Main()
Else If Component.IsActive("DETAIL B 26310C REV1:1") Then
Else If Component.IsActive("DETAIL B 26310C REV2:1") Then
End If
End Sub
 This will do only one of the options testing them in order.
Message 19 of 22
DeerSpotter
the above images: this is running the rules from the main baseline.iam
the image below is running the rule from the actual component that is being edited.
Gosh i hate doing Projects for Engineers that dont understand how to click the Return button up top. 😕
Message 20 of 22
rjay75
If you running it from the baseline assembly you need to use MakePath to get to the interior sub components.
Component.IsActive(MakePath("shell outer _ 26310c rev -:1", "DETAIL B 26310C:1"))
 Everything would have to be traversed through there subassemblies from the baseline assembly.
