Setting Drawing View labels to correct view by code (New code for you to use)
NachoShaw
Advisor Advisor
Message 1 of 1
NachoShaw
Hi
this code will change the view names to the correct view name. It will iterate through all views in a sheet and set the name & scale. There is also an option to choose scale if you dont need it.
Enjoy 🙂
Public Sub SetViewLabels()
    Dim oDoc   As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheets As Sheets
    Dim oSheet As Sheet
    Dim oViews As DrawingViews
    Dim oView  As DrawingView
    Dim iView  As Integer
    Dim iViewText As String
    Dim Ret    As Long
    Dim mBar As ProgressBar
    Ret = MsgBox("Would you like to add the Scale too?", vbYesNo)
        Set oSheets = oDoc.Sheets
        For Each oSheet In oSheets
            Set oViews = oSheet.DrawingViews
            For Each oView In oViews
                iView = oView.Camera.ViewOrientationType
                Select Case iView
                    Case 10764
                        iViewText = "FRONT ELEVATION"
                    Case 10763
                        iViewText = "ISOMETRIC VIEW"
                    Case 10754
                        iViewText = "PLAN ELEVATION"
                    Case 10757
                        iViewText = "BOTTOM ELEVATION"
                    Case 10758
                        iViewText = "LEFT ELEVATION"
                    Case 10755
                        iViewText = "RIGHT ELEVATION"
                    Case 10756
                        iViewText = "BACK ELEVATION"
                    Case 10759
                        iViewText = "TOP RIGHT ISO VIEW"
                    Case 10760
                        iViewText = "TOP LEFT ISO VIEW"
                    Case 10761
                        iViewText = "BOTTOM RIGHT ISO VIEW"
                    Case 10762
                        iViewText = "BOTTOM LEFT ISO VIEW"
                    Case Else
                End Select
                Select Case oView.ViewType
                    Case 10503
                        'TREAT THE SECTION TEXT TO LINE UP CORRECTLY
                        iViewText = "SECTION '<DrawingViewName/> - <DrawingViewName/>'"
                    Case 10502
                        iViewText = "DETAIL '<DrawingViewName/>'"
                    Case 10499
                        iViewText = "AUXILIARY VIEW - '<DrawingViewName/>'"
                    Case Else
                End Select
                Select Case Ret
                    Case 6
                        oView.Label.FormattedText = iViewText & vbCrLf & "SCALE - <DrawingViewScale/>" '& oView.ScaleString
                        oView.ShowLabel = True
                        oView.Label.ConstrainToBorder = True
                    Case Else
                End Select
            Next
        Next
End Sub
 Attached a link to a video to demonstrate
Drawing Views Demo
nigel
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Replies (0)
