Open DWG or Inventor DWG
Hi there,
I'm programming in C# with Inventor 2017/2018. I'm creating an addin that needs to open autocad DWG and Inventor DWG files. The question is, how can I determine what kind of DWG it is, in order to use AutoCAD or Inventor to open the dwg ?
Rob67ert
Hoi Remy,
as far as i know, you can't.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
frederic.vandenplas
Yes you can, before you open the file, you can check if it's an Inventor dwg or not
If InvApp.FileManager.IsInventorDWG(File.FullName) = True Then
end if
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Thanks for your reply frederick, but your solution assumes that an application is already active.
What I want is to somehow determine what kind of dwg I am dealing with and depending on that, start the appropriate application.
Something like this:
Find somekind of (windows) property which tells me what kind of dwg it is.
if (dwg,type == inventordwg) open the drawing in inventor
else open it in autocad.
The property must be somewhere, because when I double click on a dwg in the windows explorer, it knows which application to use to open it.
frederic.vandenplas
In that case the only possible solution is to see if the attributes of the file are accesible through windows explorer
I never tried that, but you can start an inventor apprentice server session, and check there if it is an Inventor dwg.
Should take only some milliseconds to recognize.
http://modthemachine.typepad.com/my_weblog/2010/03/iproperties-without-inventor-apprentice.html
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
okay, this might be a workable solution, thanks.
