Arrray export to excel
I have 7 values: X1, X2, angle A, angel B, Y1, Y2, angle C.
I would like to write these values to an array and then write that array to excel.
And if possible in this order X1, X2, angle A, angel B, Y1, Y2, angle C.
Thanks in advance
Jef_E
Do you really need it as a array? Or is sending it directly to Excel is also good? I assume the 7 values are parameters?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
well when i try to export them to excel after 20 or so values my inventor crashes and i think that it crashes because it writes every value seperatly to excel.
and i think if the values are stored in an array that array is then stored to excel it wont crash.
Jef_E
Sorry for the late reply, I did not get notified by email..
Can you please show the code that crashes? Are you using iLogic to export the values?
Inventor 2014 SP2
i solved my problem i write to notepad instead of excel .
Jef_E
Hmmm okay, still if you could I would like to look at the code 😄 to see what is wrong and solve the problem as stated in the question, rather than using a workaround?
Inventor 2014 SP2
