Open drawing from vault, save and check back in
Kassenbouw
Message 1 of 8
Kassenbouw
Hi Guys,
Does anyone have a code to for opening the drawing of a part or assembly from the vault, save it and check back in? I want to use this for updating some drawings.
I have found this code to check in all open drawings:
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/vault-check-in-through-ilogic/td-p/9811...
And this code to check out a drawing from the vault:
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/ilogic-open-drawing-from-vault-default/...
This one opens the drawing and asks if I want to check out. Is there a way to open the drawing hidden and check out without asking?
Hope someone can put these together and add the saving part.
Thanks in advance!
Replies (7)
Message 2 of 8
bradeneuropeArthur
Do you have all files locally on your workspace available, you need to open from Vault?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
bradeneuropeArthur
I have an add in that uses local files and batch some commands:
  1. Check Out From Vault
  2. Update and Save
  3. Not relevant for you at the moment
  4. Not relevant for you at the moment
  5. Not relevant for you at the moment
  6. Check In to Vault
Is this what you need?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 8
Kassenbouw
Yes all files are on my workspace. If not, i can 'Get' them from the Vault.
Message 5 of 8
Kassenbouw
This is not exactly what I was looking for but seems verry handy. Where can I get this add-in?
Does this only work with Drawing files? Or is this useable for iam and parts as well?
What I am looking for in this topic is to automaticly check-out, save (update and run rules before save) and check back in. This rule must run from the part or iam. That way I dont have to open the drawings anymore.
Message 6 of 8
bradeneuropeArthur
It is an add in created by myself.
If you are interested please send me a message and we can take look what is possible.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
Kassenbouw
After combining some pieces of code I came up with:
Dim oDoc As Document
oDoc = ThisDoc.Document
Dim oRefDoc As Document
Dim oDrawDoc As DrawingDocument
Dim xDoc As Document = ThisApplication.ActiveDocument
    For Each oRefDoc In oDoc.AllReferencedDocuments
        oBaseName = System.IO.Path.GetFileNameWithoutExtension(oRefDoc.FullFileName)
        oPathAndName = System.IO.Path.GetDirectoryName(oRefDoc.FullFileName) & "\" & oBaseName
        If(System.IO.File.Exists(oPathAndName & ".idw")) Then
            oDrawDoc = ThisApplication.Documents.Open(oPathAndName & ".idw", True)
        ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckoutTop").Execute2(False)
        xDoc.Save
        ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop").Execute2(False)
        ThisApplication.CommandManager.ControlDefinitions.Item("AppFileCloseCmd").Execute
    Next
This is for all referenced documents in my assembly.
How do I add the anwer 'OK' to the question 'Check Out / Check in'?
Message 8 of 8
tancredi.barbuscia
hallo Artur, your addin could save my life. is it possibile to have it?
