Open Document Settings dialog form at the desired (non-default/first) tab
Maxim-CADman77
Advisor Advisor
Message 1 of 9
Maxim-CADman77
I'd like to know whether it possible to open Document Settings dialog form at the desired (non-default/first) tab (let say 'Units')?
Code to open Document Settings at the default/first ('Standard') tab is:
ThisApplication.CommandManager.ControlDefinitions("AppDocumentSettingsCmd").Execute
There is also an advanced relevant sample to open non-default tab (of BOM editor dialog) by @MjDeck.
I believe it should be adaptable for the Document Settings form, but I failed to.
Here is my attempt (seems like my version of condition used for search window by title, line 66 doesn't work):
Option Explicit On
AddReference "C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\UIAutomationClient.dll"
AddReference "C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\UIAutomationTypes.dll"
Imports System.Windows.Forms
Imports System.Runtime.InteropServices
Imports System.Windows.Automation
Sub Main()
' OpenBOMEditor("Structured")
'OpenBOMEditor("Parts Only")
OpenBOMEditor("Units") ' !!
End Sub
Private Delegate Function EnumWindowsProc(ByVal hWnd As IntPtr, ByVal lParam As IntPtr) As Boolean
<DllImport("user32.dll", SetLastError :=True, CharSet :=CharSet.Auto) > _
Private Shared Function SetForegroundWindow(hWnd As IntPtr) As Integer
End Function
<DllImport("user32.dll", SetLastError :=True) > _
Private Shared Function SetActiveWindow(ByVal hWnd As IntPtr) As IntPtr
End Function
Private Shared Function EnumWindows(
	ByVal lpEnumFunc As EnumWindowsProc, _
End Function
<DllImport("user32.dll", CharSet :=CharSet.Auto) > _
Private Shared Function EnumChildWindows(ByVal hWndParent As System.IntPtr, ByVal lpEnumFunc As EnumWindowsProc, ByVal lParam As Integer) As Boolean
End Function
Private Shared Function GetWindowText(ByVal hwnd As Integer, ByVal lpString As System.Text.StringBuilder, ByVal cch As Integer) As Integer
End Function
Private Shared Function GetWindowTextLength(ByVal hwnd As IntPtr) As Integer
End Function
' see https://stackoverflow.com/questions/1363167/how-can-i-get-the-child-windows-of-a-window-given-its-hwnd
Private _tabNameWanted As String
Sub OpenBOMEditor(tabName As String, Optional sleepTime As Integer = 0)
	_tabNameWanted = tabName
	Dim oCommandMgr As CommandManager
	oCommandMgr = ThisApplication.CommandManager
	' Dim oControlDef = oCommandMgr.ControlDefinitions.Item("AssemblyBillOfMaterialsCmd")
	Dim oControlDef = oCommandMgr.ControlDefinitions.Item("AppDocumentSettingsCmd") ' !!
	Call oControlDef.Execute2(False)
	ThisApplication.UserInterfaceManager.DoEvents()
	System.Threading.Thread.Sleep(sleepTime)
	'EnumChildWindows(ThisApplication.MainFrameHWND, AddressOf FindBOMEditor, 0)
	EnumWindows(AddressOf FindBOMEditor, 0)
End Sub
Function FindBOMEditor(hWnd As IntPtr, lParam As IntPtr) As Boolean
	Dim title = GetText(hWnd)
	' If title IsNot Nothing AndAlso title.StartsWith("Bill of Materials") Then
logger.info(11)
	If title IsNot Nothing AndAlso title.EndsWith(" Document Settings") Then ' ??
logger.info(22)
		'Logger.Debug("Bill of Materials window: {0}", hWnd)
		EnumChildWindows(hWnd, AddressOf FindPane1, 0)
		Return False ' we're done
	Return True ' keep enumerating the child windows.
End Function
Function FindPane1(hWnd As IntPtr, lParam As IntPtr) As Boolean
	Dim element = AutomationElement.FromHandle(hWnd)
	If element.Current.AutomationId = "panel1" Then
		'Logger.Debug("found panel1")
		SetActiveWindow(hWnd)
		Dim tabControl = element.FindFirst(TreeScope.Descendants, New PropertyCondition(AutomationElement.AutomationIdProperty, "tabControl1"))
		If tabControl IsNot Nothing Then
			'Logger.Debug("Found tab control")
			tabControl.SetFocus()
			Dim tabPage = tabControl.FindFirst(TreeScope.Descendants, New PropertyCondition(AutomationElement.NameProperty, _tabNameWanted))
			If tabPage IsNot Nothing Then
				'Logger.Debug("Found tab page")
				Dim tabPageSelector As SelectionItemPattern = tabPage.GetCurrentPattern(SelectionItemPattern.Pattern)
				tabPageSelector.Select()
	Return True ' contine to next window
End Function
' https://www.pinvoke.net/default.aspx/user32.getwindowtext
Public Function GetText(ByVal hWnd As IntPtr) As String
	Dim length As Integer
	If hWnd.ToInt32 = 0 Then
		Return Nothing
	length = GetWindowTextLength(hWnd)
	If length = 0 Then
		Return Nothing
	Dim sb As New System.Text.StringBuilder("", length)
	GetWindowText(hWnd, sb, sb.Capacity + 1)
	Return sb.ToString()
End Function
 What I'm missing?
Please vote for Inventor-Idea Text Search within Option Names
Replies (8)
Message 2 of 9
Frederick_Law
Not sure how to code it.
Open dialog, activate "Unit" tab.
It could be in Windows Form API.
Message 3 of 9
Curtis_Waguespack
Hi @Maxim-CADman77
Here's an example of how to do this.
I hope this helps.
Curtis
Open to Units tab:
ThisApplication.CommandManager.ControlDefinitions("AppDocumentSettingsCmd").Execute2(False)
'opens to Units tab ( send "Tab" key 5 times and "right arrow" key 1 time)
SendKeys.SendWait("{TAB 5} {RIGHT 1}")
Open to Bill Of Materials tab:
SendKeys.SendWait("{TAB 5} {RIGHT 4} ")
Message 4 of 9
Maxim-CADman77
@Curtis_Waguespack
This works but if possible I'd like not to rely on Sendkeys.
Message 5 of 9
Maxim-CADman77
Seems that .EndsWith("Settings")  works (unlike .EndsWith(" Document Settings"))
But then what should I use instead of "panel1" ?
Message 6 of 9
Curtis_Waguespack
@Maxim-CADman77
I took a few minutes to look at this. I don't think the title of this dialog is returning what we expect. See the logger outputs of this version for more info. I'm not sure what window/title it is in the list, but maybe this will get you closer.
I hope this helps.
Curtis
Option Explicit On
Sub Main
	OpenTargetDialog("Units")
End Sub
End Function
End Function
End Function
End Function
End Function
End Function
Sub OpenTargetDialog(tabName As String, Optional sleepTime As Integer = 0)
	EnumChildWindows(ThisApplication.MainFrameHWND, AddressOf FindTargetWindow, 0)
	'EnumWindows(AddressOf FindTargetWindow, 0)
End Sub
Function FindTargetWindow(hWnd As IntPtr, lParam As IntPtr) As Boolean
	Dim title As String = GetText(hWnd)
	If title IsNot Nothing Then
		Logger.Debug( title)
		If title.Contains("Document Settings") Then
End Function
End Function
		Return Nothing
	If length = 0 Then
		Return Nothing
	'Logger.Info("sb " & sb.ToString())
End Function
Message 7 of 9
Maxim-CADman77
I see what you mean.
But then I don't understand why it works for "AssemblyBillOfMaterialsCmd"
For me logger doesn't list any title starting with "Bill of Materials" either...
Message 8 of 9
Waguespack_Curtis
Hi @Maxim-CADman77
I took another look at the BOM version, and I do see it get that window, but what I did just notice is that it gets it while the BOM window is still open. Whereas the Doc Settings version I posted, was only writing those titles out after the Doc Settings dialog is closed. So I suspect they are just being handled differently, but unfortunately, I don't understand it well enough to say much more.
Message 9 of 9
Zach.Stauffer
The issue might be the difference between the Bill of Materials window and the Document Settings window.
The Bill of Materials window is a non-modal window, which means you can still use the rest of the program while it is open. The Document Settings window is modal, which means all code execution stops while that window is open. Therefore the search for the Document Settings window only starts when the window is closed, and then of course it won't find the window because it has been closed.
