Relief text with ilogic
hellsensation
hellsensation
Hello colleagues
At the moment I am automating the design of standard parts. I'm having difficulty changing the text through ilogic while applying the relief, I need the user values to be entered instead D32 R60.
' ***Relief3***
Feature.IsActive("Relief3") = True
d130 = 0.2 mm
d129 = 140 mm
what should I add to the code?
A.Acheson
Hi @hellsensation
You need to first set up the text to be controlled by a text parameter. You can then control this manually by editing the parameterin the parameter dialog box. Then if you need it done by code then send your value to this parameter via a input box or form etc.
Regards
Alan
hellsensation
@A.Acheson Thank you very much for the hint, I did as you said, then added these parameters to the form and everything worked
