Description iLogic
Description iLogic
kresh.bell
Message 1 of 9
Description iLogic
kresh.bell
is it possible create rule for assembly environment for running small description window?
When I run rule I need select part, when I select part, I can add description for this part. If I select some other part, I can again add description for this selected part. When I finish with adding description, click esc or done for exit.
Accepted solutions (3)
Replies (8)
Message 2 of 9
Andrii_Humeniuk
Hi @kresh.bell . Please try this code:
Dim oInvApp As Inventor.Application = ThisApplication
Dim oAsmDoc As AssemblyDocument = oInvApp.ActiveDocument
Dim oCM As CommandManager = oInvApp.CommandManager
Do
	Dim oOcc As ComponentOccurrence = oCM.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, _
												"Select your part...")
	If oOcc Is Nothing Then Exit Sub
	If TypeOf oOcc.Definition.Document Is PartDocument Then
		Dim oPartDoc As PartDocument = oOcc.Definition.Document
		Dim oProp As Inventor.Property = oPartDoc.PropertySets("Design Tracking Properties")("Description")
		oProp.Value = InputBox("Please Enter a Description", "Description", oProp.Value)
Loop
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 9
kresh.bell
Great job, work perfect, thanks
Message 4 of 9
kresh.bell
Please, can you fix minor bug? If part already have description and if I click cancel this delete exist description. Is it possible, if part already have description that cancel do nothing?
Message 5 of 9
Curtis_Waguespack
Hi @kresh.bell ,
I started replying to this earlier but had to take a meeting, and @Andrii_Humeniuk was too fast for me! and had already provided a solution by the time I started to post this.
In any case, I had this version ready, so I'll share it also... maybe it'll help someone in the future.
It looks like the 2 versions work pretty much the same.
The primary difference I see is that Andrii's excellent version reaches down into a subassembly and gets the part, when a subassembly is selected. Whereas my example gets the subassembly description.
Also my example highlights the selected component by using the select set and puts the name in the message box, but those are minor differences.
I hope this helps.
Curtis
Dim oOccurrence As ComponentOccurrence
msg = "Select a component (press ESC to exit)"
While True
	oOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, msg)
	' If nothing gets selected then we're done
	If IsNothing(oOccurrence) Then Exit While
	oName = oOccurrence.Name
	ThisApplication.ActiveDocument.selectset.select(oOccurrence)
	oDesc = iProperties.Value(oName, "Project", "Description")
	oDesc = InputBox(oName & " Description", "iLogic", oDesc)
	If Not oDesc = Nothing Then iProperties.Value(oName, "Project", "Description") = oDesc
End While
Message 6 of 9
kresh.bell
Thanks Curtis!!!!
Message 7 of 9
kresh.bell
Curtis,
thanks again. Show selected body in your iLogic is realy very usefull.
I have one iLogic, but for part envirovment, for add chamfer to selected body. Is it posibble edit this iLogic that I see selected bodies on same way as I see selected parts in your iLogic?
Sub Main
	Dim doc As Inventor.PartDocument = ThisApplication.ActiveDocument
	Dim partdef As Inventor.PartComponentDefinition = doc.ComponentDefinition
	Dim bodyCol As Inventor.ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	For i As Integer = 1 To partdef.SurfaceBodies.Count
		Dim body As SurfaceBody = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select Body (Bodies). When you finish, Esc Key")
		If body Is Nothing Then Exit For
		If check(body, bodyCol) = False Then  bodyCol.Add(body)
	Next
	Dim distance As Double = (Double.Parse(InputBox("Chamfer distance", "MJM iLogic", 0.707))) / 10 ' 0.707
	Dim edges As EdgeCollection = ThisApplication.TransientObjects.CreateEdgeCollection()
	For Each body As Inventor.SurfaceBody In bodyCol
		For Each edge As Edge In body.Edges
			edges.Add(Edge)
		Next
	Next
	partdef.Features.ChamferFeatures.AddUsingDistance(edges, distance)
End Sub
Private Function check(input As Object, col As Inventor.ObjectCollection)
	If col.Count = 0 Then Return False
	For Each obj As Object In col
		If obj Is input Then Return True
	Next
	Return False
End Function
Message 8 of 9
Curtis_Waguespack
Hi @kresh.bell
I think here we'd want to use a highlight set, to maintain the selected components as we pick.
I hope this helps.
Curtis
Sub Main
	'https://www.rapidtables.com/web/color/index.html
	'(255, 0, 0) 'red
	'(0, 255, 0) 'green
	'(0, 0, 255) 'blue
	'(255 255, 0) 'yellow
	'(255, 0, 255) 'magenta
	'(0, 255, 255) 'cyan
	Dim HLset As HighlightSet = ThisApplication.ActiveDocument.HighlightSets.Add()
	HLset.Color = ThisApplication.TransientObjects.CreateColor(255, 255, 0) 'yellow
	While True
		If body Is Nothing Then Exit While
		HLset.AddItem(body)
	End While
	Try
		distance = (Double.Parse(InputBox("Chamfer distance", "MJM iLogic", 0.707))) / 10 ' 0.707
	Catch
		HLset.Clear
		Exit Sub
	End Try
			edges.Add(Edge)
		Next
	Next
	HLset.Clear
End Sub
	Next
	Return False
End Function
Message 9 of 9
kresh.bell
Perfect, thanks!!!
