open active doc folder
k14348
Message 1 of 8
k14348
    I would like to open the inventor active doc folder through vba or ilogic. Can somebody help on this. folder should open in file explorer not within inventor.
Sample
Sub Openpath()
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim oPath As String
oPath = oDoc.FullFileName
Call Shell("explorer.exe" & " " & "oPath", vbNormalFocus)
End Sub
Thank u,
K14348
Replies (7)
Message 2 of 8
j.brodersen
Hi k14348,
I found the code below which opens the win explorer with the path of the part it has been lunched from
Sub Main
Shell ("explorer.exe " & ThisDoc.Path, vbNormalFocus)
End Sub
Hope it's what you are looking for.
Message 3 of 8
dean.morrison
This will open your workspace folder.
Hope it helps.
Dim oFileLocations As FileLocations
Set oFileLocations = ThisApplication.FileLocations
oPath = oFileLocations.Workspace
Call Shell("explorer.exe " & oPath, vbNormalFocus)
Dean.
Message 4 of 8
k14348
Hi Dean,
            How u found  FileLocations as its not  default. Its not shown while typing in VBA.
Karthikeyan M
Message 5 of 8
dean.morrison
Unsure how i found it, it was probably on this forum somewhere.
Dean.
Message 6 of 8
Public Sub ExplorerActiveLocation()
Dim oFullfilename As String
oFullfilename = ThisApplication.ActiveDocument.fullFilename
Dim oLocation As String
oLocation = Left(oFullfilename, Len(oFullfilename) - Len(StrReverse(Left(StrReverse(oFullfilename), InStr(1, StrReverse(oFullfilename), "\") - 1))) - 1)
Shell "explorer.exe " & oLocation, vbNormalFocus
End Sub
Message 7 of 8
'Open & Select
Shell "explorer.exe /select, " & oFullfilename, vbNormalFocus
End Sub
Message 8 of 8
MichaëlStienstra
There is some code I personally use. Maybe it's helpful.
'Code voor het openen van de bestandsfolder met behulp van windows file explorer
Sub Main()
	'aanroep locatie
	oPath = ThisDoc.Path
	'open file explorer (programma)
	Dim Proc As String = "Explorer.exe"
	Dim Args As String = ControlChars.Quote & oPath & ControlChars.Quote
	Process.Start(Proc, Args)
End Sub
