Parametric model + Level of Details + associated BOM
ali.jahed
ali.jahed
Hi All,
Let me put it in a very simple example.
I have an assembly contains:
  1. Pan screw
  2. CSK Screw
Then I have Level of details (LOD) as:
  1. Master - contains both
  2. Pan - the CSK screw suppressed
  3. CSK - the Pan screw suppressed
Now:
I double click on LOD  "Pan" to make it active and what I see on the screen will be my Pan head screw; however, when I go to BOM I see both of them listed!
Is there any way to have the associated BOM to LOD?
Next level question:
in my ilogic rule when I am in "Master" LOD the following code:
ThisBOM.Export("Parts Only", "Test.xls", kMicrosoftExcelFormat)
generate the BOM having both screws listed in excel file; however, by changing the LOD to Pan (or CSK) it comes back with the following error:
Error in rule: Rule0, in document: Test.iam
ThisBOM: Could not find a BOM view named "Parts Only".
If the name is correct, then please enable this BOM view, and save the assembly.
(my comment: The name is correct and it is enable)
Please advise...
Cheers
Ali
ali.jahed
p.s. the more I investigate the more I think iAssembly is the correct choice for creating configurations. Through this way I could manage the asembly BOM right but I still cannot create the correct BOM out of iLogic rule.
marcin_otręba
Hi you can associate LOD in drawing part list.
I think you got error because Parts Only view is not enabled in BOM editor.
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
ali.jahed
Thanks for your reply,
As I mentioned previously it's enable.
voliahim_ma
Observer
Observer
Hello
Have you solved this problem?
