OnExecute Event C++ (no ATL, the simpliest way)
Fleuve
Message 1 of 1
Fleuve
Hello last week, I take some time to optimize and understand Addins for Inventor. After I realize that it's just a simple DLL with a DllGetClassObject entry and some query interface. I decide to flush the entire actual ATL template, IDL, DEF and re-begin on a new form, for my part, are really more understandable and clear. For the moment I'm not sure for the IClassFactory base class and I know it's can be again more trimmed, but anyway working fine in this way.  There is the code.
#include "pch.h"
extern "C" __declspec(selectany) const _GUID CLSID_InventorAddInLite = { 0x0B047779, 0x4EFD, 0x4ADF, {0x99, 0x24, 0x76, 0x8B, 0xF9, 0x76, 0xA6, 0x48}};
//extern "C" __declspec(selectany) const _GUID CLSID_InventorAddInServer = { 0xE3571292, 0xDB40, 0x11D2, {0xB7, 0x83, 0x00, 0x60, 0xB0, 0xF1, 0x59, 0xEF }};
unsigned long g_lockCount;
unsigned long g_objCount;
class CInventorLite : public IRxApplicationAddInServer
	public :
		CInventorLite()
			m_cRef = 0;
			g_objCount++;
		~CInventorLite()
			g_objCount--;
		virtual _declspec(nothrow) long _stdcall Activate(IRxApplicationAddInSite* pAddInSite, char FirstTime)
			if (pAddInSite == NULL)
				return E_INVALIDARG;
			m_pAddInSite = pAddInSite;
			CComPtr<IUnknown> pAppUnk;
			long hr;
			if (FAILED(hr = m_pAddInSite->get_Application(&pAppUnk)))
				return hr;
			if (FAILED(hr = pAppUnk->QueryInterface(&m_pApplication)))
				return hr;
			/*  Ribbon */
			CComPtr<UserInterfaceManager> pUserInterfaceMgr;
			hr = m_pApplication->get_UserInterfaceManager(&pUserInterfaceMgr);
			if (FAILED(hr))	return hr;
			CComPtr<Ribbons> pRibbons;
			hr = pUserInterfaceMgr->get_Ribbons(&pRibbons);
			CComPtr<Ribbon> pPartRibbon;
			hr = pRibbons->get_Item(CComVariant(_T("Assembly")), &pPartRibbon);
			//get the tabs associated with part ribbon
			CComPtr<RibbonTabs> pRibbonTabs;
			hr = pPartRibbon->get_RibbonTabs(&pRibbonTabs);
			CComPtr<RibbonTab> pRibbonTab;
			hr = pRibbonTabs->Add(CComBSTR("My Ribbon"), CComBSTR("id_Tab_MyRibbon"), CComBSTR("MyID"), CComBSTR(""), false, false, &pRibbonTab);
			CComPtr<RibbonPanel> pCustomPanel;
			pRibbonTab->GetRibbonPanels()->Add(CComBSTR("Sample"), CComBSTR("MYSample"), CComBSTR(""), CComBSTR(""), false, &pCustomPanel);
			/* Combo */
			CComPtr<CommandManager> pCommandManager;
			hr = m_pApplication->get_CommandManager(&pCommandManager);
			CComPtr<ControlDefinitions> pControlDefinitions;
			hr = pCommandManager->get_ControlDefinitions(&pControlDefinitions);
			CComPtr<ComboBoxDefinitionObject> m_pSlotWidthComboBoxDef;
			hr = pControlDefinitions->AddComboBoxDefinition(CComBSTR(_T("Slot Width")),
				CComBSTR(_T("Autodesk:SimpleAddIn:SlotWidthCboBox")),
				kShapeEditCmdType,
				50,
				CComVariant(_T("{DB59D9A7-EE4C-434A-BB5A-F93E8866E872}")),
				CComBSTR(_T("Specifies slot width")),
				CComBSTR(_T("Slot width")),
				vtMissing,
				vtMissing,
				kAlwaysDisplayText,
				&m_pSlotWidthComboBoxDef);
			CComPtr<ButtonDefinitionObject> pAddSlotOptionCmdBtnDef;
			hr = pControlDefinitions->AddButtonDefinition(CComBSTR(_T("Add Slot")),
				CComBSTR(_T("Autodesk:SimpleAddIn:AddSlotOptionCmd")),
				kShapeEditCmdType,
				CComBSTR(_T("Adds option for slot width/height")),
				CComBSTR(_T("Add slot option")),
				vtMissing,
				vtMissing,
				kDisplayTextInLearningMode,
				&pAddSlotOptionCmdBtnDef);
			CComPtr<CommandControls> pCommandControls;
			hr = pCustomPanel->get_CommandControls(&pCommandControls);
			CComPtr<CommandControl> pSlotWidthCmdCboBoxCmdCtrl;
			hr = pCommandControls->AddComboBox(m_pSlotWidthComboBoxDef, CComBSTR(""), true, &pSlotWidthCmdCboBoxCmdCtrl);
			CComPtr<CommandControl> pSlotWidthCmdButtonCmdCtrl;
			hr = pCommandControls->AddButton(pAddSlotOptionCmdBtnDef,false,	true, CComBSTR(_T("")),	false, &pSlotWidthCmdButtonCmdCtrl);
			/* End Combo*/
			MessageBox(NULL, L"Activate", L"Inventor Addins - C++ Native", MB_OK);
			return S_OK;
		virtual _declspec(nothrow) long _stdcall Deactivate()
			MessageBox(NULL, L"Desactivate", L"Inventor Addins - C++ Native", MB_OK);
			return S_OK;
		virtual _declspec(nothrow) long _stdcall ExecuteCommand(LONG CommandID)
			MessageBox(NULL, L"ExecuteCommand", L"Inventor Addins - C++ Native", MB_OK);
			return S_OK;
		virtual _declspec(nothrow) long _stdcall get_Automation(IUnknown** ppResult)
			return S_OK;
		virtual _declspec(nothrow) long _stdcall QueryInterface(const _GUID& riid, void** ppv)
			*ppv = NULL;
			long Result = E_NOINTERFACE;
			MessageBox(NULL, L"Querry Interface", L"Inventor Addins - C++ Native", MB_OK);
			//if (IsEqualGUID(riid, IID_IUnknown) || IsEqualGUID(riid, CLSID_InventorAddInServer))
			*ppv = (IUnknown*)this;
			if (*ppv)
				AddRef();
				Result = NOERROR;
			return Result;
		virtual _declspec(nothrow) unsigned long _stdcall AddRef()
			return ++m_cRef;
		virtual _declspec(nothrow) unsigned long _stdcall Release()
			if (--m_cRef == 0)
				delete this;
				return 0;
			return m_cRef;
	private:
			unsigned long m_cRef;
			CComPtr<Application> m_pApplication;
			CComPtr<IRxApplicationAddInSite> m_pAddInSite;
class CInventorLiteFactory : public IClassFactory
	public:
		CInventorLiteFactory()
			m_cRef = 0;
			g_objCount++;
		~CInventorLiteFactory()
			g_objCount--;
			*ppv = NULL;
			MessageBox(NULL, L"Querry Interface Class Factory", L"Inventor Addins - C++ Native", MB_OK);
			if (IsEqualGUID(riid, IID_IUnknown) || IsEqualGUID(riid, IID_IClassFactory))
				AddRef();
				Result = NOERROR;
			return Result;
			return ++m_cRef;
			if (--m_cRef == 0)
				delete this;
				return 0;
			return m_cRef;
		virtual _declspec(nothrow) long _stdcall CreateInstance(IUnknown* pUnkOuter, const _GUID &riid, void** ppvObject)
			long hr;
			CInventorLite* pInvLite = new CInventorLite();
			if (FAILED(hr = pInvLite->QueryInterface(riid, ppvObject)))
				delete pInvLite;
			return hr;
		virtual _declspec(nothrow) long _stdcall LockServer(int fLock)
			fLock ? g_lockCount++ : g_lockCount--;
			return S_OK;
	private:
extern "C" long _stdcall DllGetClassObject(const _GUID & rclsid, const _GUID & riid, void** ppv)
	long Result = NOERROR;
	*ppv = NULL;
	if (!IsEqualGUID(riid, IID_IUnknown) && !IsEqualGUID(riid, IID_IClassFactory))
	else if (IsEqualGUID(rclsid, CLSID_InventorAddInLite))
		if (*ppv = new CInventorLiteFactory())
			((IUnknown*)*ppv)->AddRef();
		else
			return E_OUTOFMEMORY;
	else
		Result = E_FAIL;
	return Result;
extern "C" long _stdcall DllCanUnloadNow()
	return g_lockCount == 0 && g_objCount == 0 ? S_OK : S_FALSE;
#pragma comment(linker, "/EXPORT:DllCanUnloadNow=DllCanUnloadNow,PRIVATE")
#pragma comment(linker, "/EXPORT:DllGetClassObject=DllGetClassObject,PRIVATE")
Now the question.
In C# we use m_SampleButton.OnExecute += SampleButton_OnExecute; (//oki simple ptr Function)
In VB we use AddHandler m_SampleButton.OnExecute, AddressOf m_SampleButton_OnExecute (//oki another kind)
but in C++ ATL is
SINK_ENTRY_EX (1, DIID_UserInterfaceEventsSink, UserInterfaceEventsSink_OnResetCommandBarsMeth, OnResetCommandBars)
Because I've no ATL, how to manage ButtonDefinitionHandler or ButtonDefinitionHandlerEventsSink.
Thanks.
Replies (0)
