How to attach PDF to preformatted email
Jason.Rugg
Jason.Rugg
I have a rule that pdf's a drawing and saves it next to the source file with the same name, is there a way to automatically then attach that pdf to a preformatted email message?
tyler.warner
@Jason.Rugg try this. It will use the PDF with the same name & location as the open drawing. You said you had a rule to accomplish that already so it's not included in this iLogic rule to create the email & attach the PDF.
Sub Main
	oOApp = CreateObject("Outlook.Application")
	oOMail = oOApp.CreateItem(0)
	Dim oDocument As Document = ThisApplication.ActiveDocument
    Dim oFileName As String = oDocument.DisplayName.Replace(".idw", "")
	oMessageBody = "<p style='font-family:calibri;font-size:16'>" & "Hello," & "<br><br>" & vbNewLine & vbNewLine & _
	"This is the message body of the email for drawing: " & oFileName
	' Create email.
	With oOMail
	    .bodyformat=2
	    .To = ""
	    .CC = ""
	    .BCC = ""
	    .Subject = "This is an email with a PDF of drawing: " & oFileName
	    .Display
	End With
	' Add email message.
	With oOMail
		.HTMLbody = oMessageBody & vbNewLine & .HTMLBody ' Add the signature without losing the HTML-formatting.
	End With
	' Add PDF.
	Try
		With oOMail
	    .Attachments.Add(oDocument.FullFileName.Replace(".idw", ".pdf"))
		End With
	Catch
		MsgBox("Unable to attach the PDF.")
	End Try
End Sub
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
Jason.Rugg
@tyler.warner That is sort of working, I get the following errors when running the rule. Any suggestions?
tyler.warner
@Jason.Rugg  Sorry about that, here:
Sub Main
        Dim oOApp As Object = CreateObject("Outlook.Application")
        Dim oOMail As Object = oOApp.CreateItem(0)
        Dim oMessageBody As String = "<p style='font-family:calibri;font-size:16'>" & "Hello," & "<br><br>" & vbNewLine & vbNewLine &
        ' Create email.
        With oOMail
            .bodyformat = 2
            .To = ""
            .CC = ""
            .BCC = ""
            .Display
        End With
        With oOMail
        End With
        ' Add PDF.
        Try
            With oOMail
            End With
        Catch
        End Try
End Sub
