Onchange Event (Inventor Add-In)
Hello Everyone,
I have a problem with the onchange event. Please help me in this case.
Here's my code: Add-in!
Imports Inventor
Imports System.Runtime.InteropServices
Imports Microsoft.Win32
Namespace TTF
<ProgIdAttribute("TTF.StandardAddInServer"), _
GuidAttribute(g_simpleAddInClientID)> _
Public Class StandardAddInServer
Implements Inventor.ApplicationAddInServer
Private WithEvents m_uiEvents As UserInterfaceEvents
Private WithEvents m_onChangeEvents As DocumentEvents
#Region "ApplicationAddInServer Members"
Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
Try
g_inventorApplication = addInSiteObject.Application
m_uiEvents = g_inventorApplication.UserInterfaceManager.UserInterfaceEvents
If (Not g_inventorApplication.ActiveDocument Is Nothing) Then
m_onChangeEvents = g_inventorApplication.ActiveDocument.DocumentEvents
End If
' Add to the user interface, if it's the first time.
' If this add-in doesn't have a UI but runs in the background listening
' to events, you can delete this.
If firstTime Then
AddToUserInterface()
End If
Catch ex As Exception
MsgBox("Unexpected failure in the activation of the add-in ""TTF""" & vbCrLf & vbCrLf & ex.Message)
End Try
End Sub
Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate
' Release objects.
m_onChangeEvents = Nothing
m_uiEvents = Nothing
g_inventorApplication = Nothing
System.GC.Collect()
System.GC.WaitForPendingFinalizers()
End Sub
Public ReadOnly Property Automation() As Object Implements Inventor.ApplicationAddInServer.Automation
Get
Return Nothing
End Get
End Property
Public Sub ExecuteCommand(ByVal commandID As Integer) Implements Inventor.ApplicationAddInServer.ExecuteCommand
End Sub
Private Sub m_onchangeEvents_OnChange(ByVal ReasonsForChange As CommandTypesEnum,
ByVal BeforeOrAfter As EventTimingEnum,
ByVal Context As NameValueMap,
ByRef HandlingCode As HandlingCodeEnum) Handles m_onChangeEvents.OnChange
MsgBox("Onchange")
End Sub
#End Region
#Region "User interface definition"
Private Sub AddToUserInterface()
End Sub
Private Sub m_uiEvents_OnResetRibbonInterface(Context As NameValueMap) Handles m_uiEvents.OnResetRibbonInterface
' The ribbon was reset, so add back the add-ins user-interface.
End Sub
#End Region
End Class
End Namespace
Public Module Globals
' Inventor application object.
Public g_inventorApplication As Inventor.Application
' The unique ID for this add-in. If this add-in is copied to create a new add-in
' you need to update this ID along with the ID in the .manifest file, the .addin file
' and create a new ID for the typelib GUID in AssemblyInfo.vb
Public Const g_simpleAddInClientID As String = "45065451-f806-4680-8d84-4d2166b2b77a"
Public Const g_addInClientID As String = "{" & g_simpleAddInClientID & "}"
End Module
JhoelForshav
Hi @Anonymous
I tested it this way and it works for me 🙂
I use ApplicationEvents.OnActivateDocument to see when the active document changes.
Then I set m_onChangeEvents to be the document events for that document.
        Private WithEvents oAppEvents As ApplicationEvents
            Try
                oAppEvents = g_inventorApplication.ApplicationEvents
                If firstTime Then
                End If
            End Try
        End Sub
            ' Release objects.
            System.GC.Collect()
        End Sub
            Get
                Return Nothing
            End Get
        End Property
        End Sub
            MsgBox("Onchange")
        End Sub
#End Region
        End Sub
        End Sub
        Private Sub oAppEvents_OnActivateDocument(ByVal DocumentObject As Inventor._Document, ByVal BeforeOrAfter As Inventor.EventTimingEnum, ByVal Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles oAppEvents.OnActivateDocument
            'fire after document is made active
            If BeforeOrAfter = EventTimingEnum.kAfter Then
                m_onChangeEvents = DocumentObject.DocumentEvents
            End If
        End Sub
#End Region
    End Class
JhoelForshav
Also, see how I used BeforeOrAfter to prevent oAppEvents_OnActivateDocument from fireing twice.
Your sub m_onchangeEvents_OnChange will give one messagebox before the document change and one after the change as it is written now 🙂
And i see now that i forgot to set oAppEvents to nothing in the deactivate sub... But you get the idea.
Many thanks Mr. Jhoel Forshav
