On select event not firing
CAD_CAM_MAN
Message 1 of 19
CAD_CAM_MAN
Using Inventor 2018 Ultimate debugging with visual studio 2015 community
I am trying to learn how to use interactive selections with the API (VB.net). So I started building an add in following the admapi example for user interactive selection as a tutorial. However I cannot seem to get the onselect event to fire. The admapi example is written in VBA so my code is a little different and evidently I am missing something as I am able to select edges as expected but the onselect event never fires as the admapi example suggests it should. The form is called from the StandardAddInServer...
        ' Sample handler for the button.
        Private Sub m_sampleButton_OnExecute(Context As NameValueMap) Handles m_sampleButton.OnExecute
            MsgBox("Button was clicked.")
            Dim oForm As New Form2
            oForm.Show()
        End Sub
Below is the code for the form...
Imports Inventor Public Class Form2 Private WithEvents oInteraction As InteractionEvents Private WithEvents oSelect As SelectEvents Private Sub Form2_Load(sender As Object, e As EventArgs) Handles MyBase.Load oInteraction = g_inventorApplication.CommandManager.CreateInteractionEvents oSelect = oInteraction.SelectEvents oInteraction.StatusBarText = "Select an edge" oSelect.AddSelectionFilter(SelectionFilterEnum.kPartEdgeFilter) oSelect.SingleSelectEnabled = True oInteraction.Start() End Sub Private Sub oSelect_Onselect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View) Handles oSelect.OnSelect Dim i As Long Dim dlength As Double For i = 1 To JustSelectedEntities.Item(i) Dim oEdge As Edge = JustSelectedEntities.Item(i) Dim dMin As Double Dim dMax As Double oEdge.Evaluator.GetParamExtents(dMin, dMax) Dim dSingleLength As Double oEdge.Evaluator.GetLengthAtParam(dMin, dMax, dSingleLength) dlength = dlength + dSingleLength TextBox1.Text = Format(dlength, "0.0000 cm") TextBox2.Text = JustSelectedEntities.Count Next MsgBox("IT WORKED!!!",, "") End Sub End Class
Why does the oSelect_Onselect sub not fire when the edges are selected? What am I missing?
Replies (18)
Message 2 of 19
bradeneuropeArthur
try this:
                            ByVal View As Inventor.View) Handles oSelect.OnSelect
        MsgBox(JustSelectedEntities.Count)
        Dim i As Long
        For i = 1 To JustSelectedEntities.Count
            Dim dMin As Double
            Dim dMax As Double
            TextBox1.Text = Format(dlength, "0,0000 cm")
        Next
    End Sub
The only thing is not working is the textbox1.text = format.....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 19
CAD_CAM_MAN
I see that may be an issue but I am not even getting into that sub routine to read that line. Sub oSelect_Onselect is not being read.
Message 4 of 19
bradeneuropeArthur
For me it works.
That is strange.
Please make a screen shot of the properties setting of the inventor.interop library.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 19
CAD_CAM_MAN
Message 6 of 19
bradeneuropeArthur
Copy local to false....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 19
CAD_CAM_MAN
There may be another issue here. I just commented out a line of code that displays a message box but the message box is still popping up when I start the add in...
            'MsgBox("Button was clicked.")
            oForm.Show()
Something else I notice now is the break points are not being hit. Its as if it is not connected to the edits I am making. I tried a clean and rebuild but same issues. Selection filter is not working either now though it was earlier today. Do I need to unload the add in or something?
Message 8 of 19
CAD_CAM_MAN
Same result. Still not firing after setting copy local to false.
Message 9 of 19
bradeneuropeArthur
because you are creating a new form:
 Public Sub New()
        ' This call is required by the designer.
        InitializeComponent()
        ' Add any initialization after the InitializeComponent() call.
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 19
CAD_CAM_MAN
No Symbols have been loaded for this document? How do I load them?
Message 11 of 19
bradeneuropeArthur
and use this reference to inventor library instead of yours:
C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Autodesk.Inventor.Interop\v4.0_22.0.0.0__@@@@@@@\Autodesk.Inventor.Interop.dll
set copy local to false
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 19
CAD_CAM_MAN
Still not working. Something is disconnected somewhere how can it be that a line of code is commented out yet is still being read?
Message 13 of 19
bradeneuropeArthur
For me it works fine.
With the above settings.
What inventor version are you using?
Is this an add in or standalone application?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 19
CAD_CAM_MAN
This is an add in.
Inventor professional 2018 64-bit edition build: 227, Release 2018.2.3 - Date: Tue 01/16/2018.
Message 15 of 19
bradeneuropeArthur
That is strange. Working for me and for you not!
Let's take a closer look tomorrow...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 19
CAD_CAM_MAN
Thank you for your help!  Make that Monday  Smiley Wink
Message 17 of 19
bradeneuropeArthur
Where is the  "g_inventorApplication" declared and how is it passed to the form2?
This is your code.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 19
CAD_CAM_MAN
Started working on this again this morning and noticed my addin button was missing from the tools tab when debugging. I went to the add ins manager and noticed the add in was unloaded so I tried to load it and it would not load. Stopped the debugger and started again, the button now appears and the add in shows as loaded. Miraculously everything seems to be working correctly now... Breakpoints are being hit, and the on select event is now firing. I did not change anything in the code from last Friday. Evidently my machine just needed restarted?
In any case the g_inventorApplication is defined in the standard add in server namespace...
Imports Inventor
Imports System.Runtime.InteropServices
Imports Microsoft.Win32
Namespace ADDIN_TEST
    <ProgIdAttribute("ADDIN_TEST.StandardAddInServer"), _
    GuidAttribute("2cf6734b-fa00-4dfa-b0e7-fbc893cc76e4")> _
    Public Class StandardAddInServer
        Implements Inventor.ApplicationAddInServer
        Private WithEvents m_uiEvents As UserInterfaceEvents
        Private WithEvents m_sampleButton As ButtonDefinition
#Region "ApplicationAddInServer Members"
        ' This method is called by Inventor when it loads the AddIn. The AddInSiteObject provides access
        ' to the Inventor Application object. The FirstTime flag indicates if the AddIn is loaded for
        ' the first time. However, with the introduction of the ribbon this argument is always true.
        Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
            ' Initialize AddIn members.
            g_inventorApplication = addInSiteObject.Application
            ' Connect to the user-interface events to handle a ribbon reset.
            m_uiEvents = g_inventorApplication.UserInterfaceManager.UserInterfaceEvents
            ' TODO: Add button definitions.
            ' Sample to illustrate creating a button definition.
            Dim largeIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.BMAP1)
            Dim smallIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.BMAP1)
            Dim controlDefs As Inventor.ControlDefinitions = g_inventorApplication.CommandManager.ControlDefinitions
            m_sampleButton = controlDefs.AddButtonDefinition("EdgeSelect", "Internal Name", CommandTypesEnum.kShapeEditCmdType, AddInClientID)
            ' Add to the user interface, if it's the first time.
            If firstTime Then
                AddToUserInterface()
        End Sub
The form is called from the add in button execute event found in the same namespace...
            oForm.Show()
        End Sub
I guess this is solved now, but would like to know what happened and what changing the references copy local to False does?
Message 19 of 19
bradeneuropeArthur
it overwrites the default and there is the conflict..
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
