oControlDef = ThisApplication.CommandManager.ControlDefinitions("PartiFeatureIns
hi!
i use ThisApplication.CommandManager.ControlDefinitions("PartiFeatureInsertCmd")
and i want to have the name of iFeature selection with ilogic?
Thanks for your help 🙂
frederic.vandenplas
You can send extra information to a command (if you see it as a selectionset before activating a command)
This page explains alot about the commandmanager
http://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
And you need something like this
Public Sub PlacePart()
    ' Get the command manager.
    Dim oCommandMgr As CommandManager
    Set oCommandMgr = ThisApplication.CommandManager
    ' Post the filename.
    Call oCommandMgr.PostPrivateEvent(kFileNameEvent, _
         "C:\Users\ekinsb\Documents\Inventor 2010\Showcasetest.ipt")
    ' Get control definition for the place component command.
    Dim oControlDef As ControlDefinition
    Set oControlDef = oCommandMgr.ControlDefinitions.Item( _
                                    "AssemblyPlaceComponentCmd")
    ' Execute the command.
    Call oControlDef.Execute
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
thanks for your reply Frederic!
I see this link before but nothing about what i"m looking for!
Sorry for my English 😞
The code i try to make!
SyntaxEditor Code Snippet
Dim oDoc As Document
Dim oCompDef As PartComponentDefinition
oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oiFeatComp As iFeatureComponent
'Get control definition
oControlDef = ThisApplication.CommandManager.ControlDefinitions("PartiFeatureInsertCmd")
' Execute the command synchronously.
Call oControlDef.Execute2(True)
Dim strPrompt As String
strPrompt = oiFeatComp.Name
iProperties.Value("Custom", "TEST") = strPrompt
I want the name of iFeature who is selected by the user.
frederic.vandenplas
This code does what you where looking for, only you need to create a few lines of code to extract the filename.
now the full path is created in the iproperties.
I found it through debugging in vba, which you wont find easy in help or in ilogic
oiFeatComp = oCompDef.Features.iFeatures(oCompDef.Features.iFeatures.Count)
strPrompt = oiFeatComp.iFeatureTemplateDescriptor.LastKnownSourceFileName
thank you very much Frederic 🙂
