Generate bitmap from part file using apprentice
Raider_71
Raider_71
Hi guys something I have never played with but something I would like to do now. I am trying to use apprentice to generate a bitmap in a predefined orientation and saving the bitmap to file. I am using sample code from Brian Ekins' AU handout - CP5605 but the code is just not working.
This is what I have so far:
' Create an instance of Apprentice.
        Dim apprentice As New Inventor.ApprenticeServerComponent
        ' Open a document.
        Dim doc As Inventor.ApprenticeServerDocument
        doc = apprentice.Open("c:\file.ipt")
        ' Create a camera to define an iso view.
        Dim camera As Inventor.Camera = apprentice.TransientObjects.CreateCamera
        ' Assign the component definition to camera so it knows what it's looking at.
        'THIS IS WHERE IT FAILS
camera.SceneObject = doc.ComponentDefinition ' Set the orientation, fit the view, and apply it. 'THIS IS WHERE IT FAILS AS WELL
camera.ViewOrientationType = Inventor.ViewOrientationTypeEnum.kIsoTopRightViewOrientation camera.Fit() camera.Apply() ' Get an image of what the camera currently sees. Dim cameraResults As stdole.IPictureDisp = camera.CreateImage(300, 300)
Has anyone got some pointers for me?
Thanks and cheers!
wayne.brill
I do not have good news for this. It is a known issue that was discussed by my colleague in this forum post:
http://forums.autodesk.com/t5/inventor-customization/apprentice-server-com-exception-with-inventor-2...
I have added a note to the Inventor Engineering ticket that this issue was reported again in this post. I find that the problem still exists in Inventor 2017.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Raider_71
Hi Wayne,
Thanks for the feedback. Do you think this will be fixed in a service pack at all?
wayne.brill
We have had several reports of this issue and have let Inventor Engineering know that this problem is a high priority. I am not sure when a fix for this will be provided.
Wayne
Wayne Brill
