occurrence parent = pattern
I have a external rule that replaces occurrences.
Now I have to make an exclusion for some occurrences in a pattern.
My solution is to check if the occurrence is inside a pattern with a specfic name (oPat.Name.Contains("#Sub"))
I made working code the other day , accidently deleted my code, and now I can't replicate it anymore.
Note: I do not want to use oOcc.ispatternelement, I want to check the name of the parent if that parent is a pattern.
SyntaxEditor Code Snippet
Dim oDoc As AssemblyDocument  = ThisDoc.Document
Dim Occurrences As ComponentOccurrences = oDoc.ComponentDefinition.Occurrences
Dim oOcc As ComponentOccurrence
For Each oOcc In Occurrences
    If oOcc.Parent.Type = ObjectTypeEnum.kOccurrencePatternObject Then
        MsgBox("yay it works")
    End If
Next
Thanks in advance
Arnold
Vladimir.Ananyev
If ComponentOccurrence is a pattern member then its ComponentOccurrence.PatternElement.Parent property returns the reference to the parent pattern object:
Set oOcc = oAsmDef.Occurrences.Item(15)  '<--- some component, rect. pattern member
Dim oPattern As RectangularOccurrencePattern
Set oPattern = oOcc.PatternElement.Parent
Debug.Print oPattern.name
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
