Occasional "Object Variable or With block Variable Not Set" Error on ext. iLogic
Maxim-CADman77
Advisor Advisor
Message 1 of 25
Maxim-CADman77
We do have set of external iLogic rules running automatically on Open and Save Inventor Documents with IDC (Inventor Design Checker).
Some (AFAIK only two particular) IPT oriented rules sometimes produce error "Object Variable or With block Variable Not Set".
Here is a bit simplified code of one:
Try
Dim oCompdef As PartComponentDefinition
oCompdef = ThisDoc.Document.ComponentDefinition
Dim oSketch As Sketch
''' Initial argument values
msg = "There were no unused sketches found."
retval = 1
For each oSketch in oCompdef.Sketches
	If oSketch.HealthStatus <> HealthStatusEnum.kBeyondStopNodeHealth And oSketch.Consumed = False	Then
		msg = "There is at least one unused sketch - " & oSketch.Name
		retval = 0
Exit For
	End if
Next
RuleArguments.Arguments.Value("ReturnValue") = retval
RuleArguments.Arguments.Value("Description") = msg
Catch
End Try
Trace.WriteLine (retval & "; " & msg)
The Error occurs occasionally. I see no relation to particular IPTs. Sometimes it even happens on creating new IPT. Sometimes Inventor reboot helps.
How could I debug such occasional errors?
Please vote for Inventor-Idea Text Search within Option Names
Replies (24)
Message 21 of 25
DRoam
Ok, good to know. I'll post back here if it ever does cause the Member Not Found error.
Yeah, if I understand you correctly, that's what I would expect. I think (hope) the GetCompDef function should always return the proper ComponentDefinition type for the type of document being processed (for example, a Part should return a PartComponentDefinition object and an assembly should return an AssemblyComponentDefinition object), so only the ComponentDefinition properties and methods appropriate to the document type should be available. If I tried to do something like this:
Dim oPartDoc As PartDocument = ThisDoc.Document
Dim oCompDef = GetCompDef(oPartDoc)
Dim oConstraints = oCompDef.Constraints
... the third line would produce an error, because the PartComponentDefintion object has no Constraints property.
The "GetCompDef" function should hopefully return the same result as doing "Document.ComponentDefinition" would return in Inventor 2019.2+. The result could be a PartComponentDefinition, or it could be an AssemblyComponentDefinition, depending on which document type was passed in. It's up to the person writing the code to make sure that only methods and properties shared by both Part and Assembly ComponentDefinitions are used (or else add necessary provisions for handling type-specific operations).
Please correct me if I'm understanding anything incorrectly.
Message 22 of 25
MjDeck
That's right, your "GetCompDef" function will return the same result as "Document.ComponentDefinition" would return in Inventor 2019.2+.
Then ideally you could use a single piece of code to access properties (e.g. the Parameters property) that are in common to both PartComponentDefinition and AssemblyComponentDefinition. I don't have any evidence of that failing. But I'm reluctant to recommend it, just because the situation is similar to the one between PartDocument and AssemblyDocument. In that case, the ComponentDefinition property looks like it's in common, but it's not really. That's what caused problems before the 2019.2 fix.
I will do more investigation to find out if PartComponentDefinition and AssemblyComponentDefinition could ever throw a "member not found" error with members that they have in common.
Mike Deck
Software Developer
Autodesk, Inc.
Message 23 of 25
drouthierXAHY9
Hi Mike!
I'm having this issue in Inventor 2017.
The error will get thrown "randomly" and upon restart it will sometimes work.
I tried the solution provided  here by Xiaodong Liang and it doesn't alleviate the problem.
will the fix be implemented in "Inventor" 2017?
Below is a snippet of my code.
ElseIf oRefDoc.documenttype = 12291		'assemblyDocumemt
Dim oAssyCompDef As assemblyComponentDefinition = oRefDoc.componentdefinition
Message 24 of 25
DRoam
@drouthierXAHY9, if you're pre-2019 then you'll need to explicitly declare the document as an assembly document before trying to get its AssemblyComponentDefinition. Try this and see if it works better for you:
Dim oAssyDoc As AssemblyDocument = oRefDoc
Dim oAssyCompDef As assemblyComponentDefinition = oAssyDoc.componentdefinition
Message 25 of 25
drouthierXAHY9
Thanks DRoam!
I "overlooked" that part of Mike's response. hahaha Man-eyes!
