AssemblyComponentDefinition throws member not found
mrattray
Advisor Advisor
Message 1 of 8
mrattray
I have two assembly files which throw a "member not found" error when running the following line of code in iLogic:
oAsmCompDef = ThisDoc.Document.ComponentDefinition
I've tried with declaring oAsmCompDef as either ComponentDefinition or AssemblyComponentDefinition and without declaring it. All variations fail.
I tried one of these assemblies on a co-workers machine with no difference.
Other assembly files run fine.
I'm using Inventor 2015.
Any ideas would be appreciated.
Mike (not Matt) Rattray
Replies (7)
Message 2 of 8
xiaodong_liang
Autodesk Support
Autodesk Support
I gave a simple test on  my Inventor 2015. It works well. The attachment is the video.
Does this problem occur with specific document?
Message 3 of 8
mrattray
Sorry, I should've attached the file to begin with.
Please, open the attached file. It's an empty assembly with just one rule (for reproduction purposes). Skip any missing references, they're not needed to show the issue. Try running Rule1. It only contains the above code which should throw a member not found error.
Message 4 of 8
xiaodong_liang
Autodesk Support
Autodesk Support
Hi Mike,
sorry, my video was not uploaded successfully last time.
I used your assembly to test again. The rule can still work without error. The video is available at:
https://autodesk.box.com/s/t4d4z1o0bvnn5u555zbl
Could you take a look?
Message 5 of 8
mrattray
Well, this is frustrating.
When I posted that file I did the same steps you did in order to reproduce the problem multiple times and each time threw the error. Now, after the holiday, I tried again in order to record a video for you and I can no longer reproduce the problem either with this file nor the original file.
I'm confident that this will come up again as it seems to be an issue that comes and goes. When it does I'll be sure to get a video of it.
In the mean time, do you have any theories as to what could cause something like this? If you did get an error what would be the first thing you looked at?
Message 6 of 8
mrattray
I knew it would crop up again. This time it's in a part file. Here's a video I captured here.
I'll attach the part file to this post.
Message 7 of 8
xiaodong_liang
Autodesk Support
Autodesk Support
Hi Mike,
I got the comments from our engineer team. Could you check if it helps?
This problem is caused by interaction with other addins. It depends on the history of a particular Document object in a session. It’s hard to reproduce. But there is a workaround: declare a document object of a specific type.
Instead of the statement:
In an assembly, use these statements:
Dim assemDoc As AssemblyDocument = ThisDoc.Document
oAsmCompDef = assemDoc.ComponentDefinition
In a part, use these:
Dim partDoc As PartDocument = ThisDoc.Document
oPartCompDef = partDoc.ComponentDefinition
Message 8 of 8
mrattray
This seems to work. Thank you, very much!
