Standard Drawing Template - PDF Line Weight
I am currently working on a new drawing template for the company.
As you probably are aware, when exporting the idw to PDF, the line weight of the document is almost always wrong, and if I mark the box to remove the line weights, then everything has same line weight.
Is there a standard template inventor built-in, that can export PDF with correct line weights, or at least close enough for it to work properly? I would like to use that as my starting base for template.  Sheet Size is A2 or A3, but should it be other page, probably I can work around that too.
I am okay with the rest of template creation, but this one particular field (the line weights) I find them to be very good on screen, and I would be happy to have that printed same way.
dgreatice
hi,
Can you use standard template from Inventor? in standard template drawing inventor, line weight already same with standard ISO.
now what problem?
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Sorry  - It actually worked-  I did not try on the 2019 version, all I remembered was the previous versions I had, probably back in Inventor 2019 where the line weight was an issue on exported PDFs
Jon.Dean
Hi @Anonymous Thanks for the update and great to hear the problem is now fixed in the latest version of Inventor 2019.
Jon Dean
I meant Inventor 2015 - I had issues with line weight, and since then up until now, I did not bother either fixing or looking into it, I used  to use the Remove Object Line Weight option.
dgreatice
maybe you can find some information in autodesk update service pack for inventor 2015, are there bug for line weight.
