Numbering For the Stairs or Disc Stack
JadhavP1
JadhavP1
I wish to do numbering on the .idw file which has a base view for zigzag stairs. I want to number the stairs as (#1, #2 , #3.....so on. Is there any way by which we can number the stairs on a click. A message prompt at start for the numbering start from value & later on, on every clicks it shall be incremental text appear on the sheet.
JhoelForshav
Hi @JadhavP1
You can add this iLogic rule to the drawing document and run it.
It asks you to give the start number and after that you can just klick anywhere on the drawing to place annotations.
Exit the function with esc-key 🙂
Public Sub Main()
	Dim oDoc As DrawingDocument = ThisDoc.Document
	Dim oSheet As Sheet = oDoc.ActiveSheet
	Dim oStartVal As Integer = InputBox("Start value", "Set start value", 1)
	Dim getPoint As New clsGetPoint
	Dim pnt As Point2d
	Do
		pnt = getPoint.GetDrawingPoint("Click the desired location", MouseButtonEnum.kLeftMouseButton)
		If Not pnt Is Nothing Then
			oSheet.DrawingNotes.GeneralNotes.AddFitted(pnt, "#" & oStartVal)
			oStartVal += 1
		End If
	Loop While Not pnt Is Nothing
End Sub
Class clsGetPoint
	Private WithEvents m_interaction As InteractionEvents
	Private WithEvents m_mouse As MouseEvents
	Private m_position As Point2d
	Private m_button As MouseButtonEnum
	Private m_continue As Boolean
	Public Function GetDrawingPoint(Prompt As String, button As MouseButtonEnum) As Point2d
		Dim ThisApplication As Inventor.Application = GetObject(Nothing,"Inventor.Application")
		m_position = Nothing
		m_button = button
		m_interaction = ThisApplication.CommandManager.CreateInteractionEvents
		m_mouse = m_interaction.MouseEvents
		m_interaction.StatusBarText = Prompt
		m_interaction.Start
		m_continue = True
		Do
			ThisApplication.UserInterfaceManager.DoEvents
		Loop While m_continue
		m_interaction.Stop
		GetDrawingPoint = m_position
	End Function
	Private Sub m_mouse_OnMouseClick(ByVal button As MouseButtonEnum, ByVal ShiftKeys As ShiftStateEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View) Handles m_mouse.OnMouseClick
	Dim ThisApplication As Inventor.Application = GetObject(Nothing, "Inventor.Application")
		If button = m_button Then
			m_position = ThisApplication.TransientGeometry.CreatePoint2d(ModelPosition.X, ModelPosition.Y)
		End If
		m_continue = False
	End Sub
End Class
JhoelForshav
Hi @JadhavP1
The code I posted earlier gets stuck in a loop!
Even though it at first seems like inventor behaves as normal after you hit esc, some functionalities are blocked due to a lingering handler.
This code however should work 🙂
I make sure pnt is actually set to nothing when you terminate the interaction with esc and then i do a bit of clean-up setting the events to nothing.
Public Sub Main()
	Dim pnt As Point2d
	Do
			oStartVal += 1
		End If
	getPoint.CleanUp
End Sub
Class clsGetPoint
		m_button = button
		m_interaction.Start
		m_continue = True
		Do
		m_interaction.Stop
	End Function
		End If
		m_continue = False
	End Sub
	Private Sub oInteraction_OnTerminate() Handles m_interaction.OnTerminate
        m_continue = False
    End Sub
	Public Sub CleanUp
		m_mouse = Nothing
        m_interaction = Nothing
	End Sub
End Class
I apologise if you had to restart inventor due to testing my previous code.
JadhavP1
Hello jhoel.forshav
Thanks This worked perfectly, but an we have an option to set the text alignment at the start where we are providing input for the starting number. I mean whether to have text clockwise 90 or ACCW 90 (vertical or horizontal).
JhoelForshav
Hi @JadhavP1
I'm glad it worked for you!
Try this to also set the rotation 🙂
Public Sub Main()
	Dim oRotation As Double = InputBox("Set CCW rotation:", "Set rotation", 90)
	Dim pnt As Point2d
	Do
			Dim oNote As GeneralNote = oSheet.DrawingNotes.GeneralNotes.AddFitted(pnt, "#" & oStartVal)
			oNote.VerticalJustification = VerticalTextAlignmentEnum.kAlignTextMiddle
			oNote.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter
			oNote.Position = pnt
			oNote.Rotation = oRotation * PI/180
			oStartVal += 1
		End If
	getPoint.CleanUp
End Sub
Class clsGetPoint
		m_button = button
		m_interaction.Start
		m_continue = True
		Do
		m_interaction.Stop
	End Function
		End If
		m_continue = False
	End Sub
		m_continue = False
	End Sub
	Public Sub CleanUp
		m_mouse = Nothing
	End Sub
End Class
JadhavP1
Perfect Code as required. Thank You 🙂
adamXL2U2
Observer
Observer
I don't know what's going on with my inventor but the code gives an error on line 34 when I enter the session to use the left mouse click... do I have to change some configuration within the inventor? Or the code may be out of date?
