MessageBox width (and height)
b.graaf
b.graaf
Can I somehow change of influence the width (and height) of a messagebox, placed with iLogic?
b.graaf
Hm, I have found a very nice alternative using Windows forms, with a lot of possible options:
iLogic and Windows forms
WCrihfield
I created the following request in Inventor Ideas late last year for the same thing.
If enough of us vote for it, it may get implemented into newer versions of Inventor.
Text Format & Size Options for MessageBox, InputBox, InputListBox, & InputRadioBox
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
There is also the FormattedText option, which allows you to use XML programming code to specify the format of the text within a String.  Then you could show that String within a MsgBox or MessageBox.Show.  But it is slightly complicated for basic needs.  The Forms are the way to go if you want a lot of specifics.
Wesley Crihfield
