- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Am working on an Assembly addin, this is a combination of the simpleaddin from the sample files and help from this forum that I had on a previous post:
https://forums.autodesk.com/t5/inventor-customization/my-first-addon-help/m-p/6249591#M62851
I have managed to get the addin to load the toolbar button and fire from within an assembly file, this is where I am having the issue.
Like before I am getting a null reference error on line 16 on my form's code. (See attached screen grab) But unlike before the fixes will not work.
This is the code I have in the project:
Globals.Vb:
Module Globals Public InvApp As Inventor.Application End Module
StandardAddInServer:
Imports Inventor Imports System.Drawing Imports System.Windows.Forms Imports System.Runtime.InteropServices Imports System.Configuration Imports Microsoft.Win32 Namespace SimpleAddIn <ProgIdAttribute("SimpleAddIn.StandardAddInServer"), _ GuidAttribute("E6EA2F87-0494-4C0D-9E05-9e71128cae77")> _ Public Class StandardAddInServer Implements Inventor.ApplicationAddInServer Private WithEvents oAppEvents As ApplicationEvents #Region "Data Members" Private Invapp As Inventor.Application 'buttons Private m_StudboltToolButton As StudboltToolButton 'events Private m_userInterfaceEvents As UserInterfaceEvents ' ribbon panel Private m_partSketchSlotRibbonPanel As RibbonPanel #End Region #Region "ApplicationAddInServer Members" Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate Try 'the Activate method is called by Inventor when it loads the addin 'the AddInSiteObject provides access to the Inventor Application object 'the FirstTime flag indicates if the addin is loaded for the first time 'initialize AddIn members Invapp = addInSiteObject.Application Button.InventorApplication = Invapp 'initialize event handlers m_userInterfaceEvents = Invapp.UserInterfaceManager.UserInterfaceEvents AddHandler m_userInterfaceEvents.OnResetCommandBars, AddressOf Me.UserInterfaceEvents_OnResetCommandBars AddHandler m_userInterfaceEvents.OnResetEnvironments, AddressOf Me.UserInterfaceEvents_OnResetEnvironments AddHandler m_userInterfaceEvents.OnResetRibbonInterface, AddressOf Me.UserInterfaceEvents_OnResetRibbonInterface 'load image icons for UI items Dim StudboltToolImageStream As System.IO.Stream = Me.GetType().Assembly.GetManifestResourceStream("SimpleAddIn.Studbolt.ico") Dim StudboltToolIcon As Icon = New Icon(StudboltToolImageStream) 'retrieve the GUID for this class Dim addInCLSID As GuidAttribute addInCLSID = CType(System.Attribute.GetCustomAttribute(GetType(StandardAddInServer), GetType(GuidAttribute)), GuidAttribute) Dim addInCLSIDString As String addInCLSIDString = "{" & addInCLSID.Value & "}" 'create buttons m_StudboltToolButton = New StudboltToolButton("Studbolt Tool", "Autodesk:SimpleAddIn:StudboltToolCmdBtn", CommandTypesEnum.kShapeEditCmdType, _ addInCLSIDString, "Studbolt Tool", "Studbolt Tool", StudboltToolIcon, StudboltToolIcon) 'create the command category Dim AssmCmdCategory As CommandCategory = Invapp.CommandManager.CommandCategories.Add("Company Assembly Tools", "Autodesk:SimpleAddIn:AssmCmdCat", addInCLSIDString) AssmCmdCategory.Add(m_StudboltToolButton.ButtonDefinition) If firstTime = True Then 'access user interface manager Dim userInterfaceManager As UserInterfaceManager userInterfaceManager = Invapp.UserInterfaceManager Dim interfaceStyle As InterfaceStyleEnum interfaceStyle = userInterfaceManager.InterfaceStyle m_partSketchSlotRibbonPanel = Nothing ' create the UI for classic interface If interfaceStyle = InterfaceStyleEnum.kClassicInterface Then 'create toolbar Dim slotCommandBar As CommandBar slotCommandBar = userInterfaceManager.CommandBars.Add("Company Assembly Tools", "Autodesk:SimpleAddIn:SlotToolbar", , addInCLSIDString) 'add buttons to toolbar slotCommandBar.Controls.AddButton(m_StudboltToolButton.ButtonDefinition) 'get the 2d sketch environment base object Dim partSketchEnvironment As Inventor.Environment partSketchEnvironment = userInterfaceManager.Environments.Item("PMxPartSketchEnvironment") 'make this command bar accessible in the panel menu for the 2d sketch environment partSketchEnvironment.PanelBar.CommandBarList.Add(slotCommandBar) 'create UI for ribbon interface Else ' get the ribbon associated with part document Dim ribbons As Ribbons ribbons = userInterfaceManager.Ribbons Dim partRibbon As Ribbon partRibbon = ribbons.Item("Assembly") ' get the tabs associated with part ribbon Dim ribbonTabs As RibbonTabs ribbonTabs = partRibbon.RibbonTabs Dim partSketchRibbonTab As RibbonTab partSketchRibbonTab = ribbonTabs.Item("id_TabDesign") ' create a new panel within the tab Dim ribbonPanels As RibbonPanels ribbonPanels = partSketchRibbonTab.RibbonPanels Dim m_partSketchSlotRibbonPanel As RibbonPanel m_partSketchSlotRibbonPanel = ribbonPanels.Add("Company Assembly Tools", "Autodesk:SimpleAddIn:SlotRibbonPanel", "{E6EA2F87-0494-4C0D-9E05-9e71128cae77}", "", False) ' add controls to the slot panel Dim partSketchSlotRibbonPanelCtrls As CommandControls partSketchSlotRibbonPanelCtrls = m_partSketchSlotRibbonPanel.CommandControls ' add the buttons to the ribbon panel Dim StudboltCmdCtrl As CommandControl StudboltCmdCtrl = partSketchSlotRibbonPanelCtrls.AddButton(m_StudboltToolButton.ButtonDefinition, False, True, "", False) End If End If Catch ex As Exception MessageBox.Show(ex.ToString) End Try End Sub Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate 'the Deactivate method is called by Inventor when the AddIn is unloaded 'the AddIn will be unloaded either manually by the user or 'when the Inventor session is terminated Try 'release objects RemoveHandler m_userInterfaceEvents.OnResetCommandBars, AddressOf Me.UserInterfaceEvents_OnResetCommandBars RemoveHandler m_userInterfaceEvents.OnResetEnvironments, AddressOf Me.UserInterfaceEvents_OnResetEnvironments m_StudboltToolButton = Nothing If Not m_partSketchSlotRibbonPanel Is Nothing Then m_partSketchSlotRibbonPanel.Delete() m_userInterfaceEvents = Nothing Marshal.ReleaseComObject(Invapp) Invapp = Nothing System.GC.WaitForPendingFinalizers() System.GC.Collect() Catch ex As Exception MessageBox.Show(ex.ToString) End Try End Sub Public ReadOnly Property Automation() As Object Implements Inventor.ApplicationAddInServer.Automation 'if you want to return an interface to another client of this addin, 'implement that interface in a class and return that class object 'through this property Get Return Nothing End Get End Property Public Sub ExecuteCommand(ByVal CommandID As Integer) Implements Inventor.ApplicationAddInServer.ExecuteCommand 'this method was used to notify when an AddIn command was executed 'the CommandID parameter identifies the command that was executed 'Note:this method is now obsolete, you should use the new 'ControlDefinition objects to implement commands, they have 'their own event sinks to notify when the command is executed End Sub Public Sub UserInterfaceEvents_OnResetCommandBars(ByVal commandBars As ObjectsEnumerator, ByVal context As NameValueMap) Try Dim commandBar As CommandBar For Each commandBar In commandBars If commandBar.InternalName = "Autodesk:SimpleAddIn:SlotToolbar" Then 'add buttons to toolbar commandBar.Controls.AddButton(m_StudboltToolButton.ButtonDefinition) Exit Sub End If Next Catch End Try End Sub Public Sub UserInterfaceEvents_OnResetEnvironments(ByVal environments As ObjectsEnumerator, ByVal context As NameValueMap) Try Dim environment As Environment For Each environment In environments 'get the 2d sketch environment If environment.InternalName = "PMxPartSketchEnvironment" Then 'make the command bar accessible in the panel menu for the 2d sketch environment environment.PanelBar.CommandBarList.Add(Invapp.UserInterfaceManager.CommandBars.Item("Autodesk:SimpleAddIn:SlotToolbar")) Exit Sub End If Next Catch End Try End Sub Public Sub UserInterfaceEvents_OnResetRibbonInterface(ByVal Context As Inventor.NameValueMap) ' get UserInterfaceManager Dim userInterfaceManager As UserInterfaceManager userInterfaceManager = Invapp.UserInterfaceManager ' get the ribbon associated with part documents Dim ribbons As Ribbons ribbons = userInterfaceManager.Ribbons Dim partRibbon As Ribbon partRibbon = ribbons.Item("Assembly") ' get the tabs associated with part ribbon Dim ribbonTabs As RibbonTabs ribbonTabs = partRibbon.RibbonTabs Dim partSketchRibbonTab As RibbonTab partSketchRibbonTab = ribbonTabs.Item("id_TabDesign") ' create a new panel within the tab Dim ribbonPanels As RibbonPanels ribbonPanels = partSketchRibbonTab.RibbonPanels Dim partSketchSlotRibbonPanel As RibbonPanel partSketchSlotRibbonPanel = ribbonPanels.Add("Company Assembly Tools", "Autodesk:SimpleAddIn:SlotRibbonPanel", "{E6EA2F87-0494-4C0D-9E05-9e71128cae77}", "", False) ' add controls to the slot panel Dim partSketchSlotRibbonPanelCtrls As CommandControls partSketchSlotRibbonPanelCtrls = partSketchSlotRibbonPanel.CommandControls ' add the buttons to the ribbon panel Dim StudboltCmdCtrl As CommandControl StudboltCmdCtrl = partSketchSlotRibbonPanelCtrls.AddButton(m_StudboltToolButton.ButtonDefinition, False, True, "", False) End Sub #End Region End Class End Namespace
Form: StudboltTool
Imports Inventor Imports System.Drawing Imports System.Windows.Forms Imports System.Runtime.InteropServices Imports System.Configuration Imports Microsoft.Win32 Public Class StudboltTool Public Sub New() ' This call is required by the designer. InitializeComponent() Dim ADoc As AssemblyDocument = InvApp.ActiveDocument ' Add any initialization after the InitializeComponent() call. End Sub Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click Dim ADoc As AssemblyDocument = InvApp.ActiveDocument MsgBox(ADoc.DisplayName) End Sub End Class
As always, any help is greatly appreciated.
Inventor Pro 2015, SP2
Visual Studio Pro 2010
