HowTo check object type?
Hi!
I made an AddIn that works with centermarks and centerlines. I use this frequently but I found an bug in my program.
If you use automated centerlines to for a flange bolt pattern you get a circle on the bolt diameter and centerline on the holes. But this centerline is not the same type of line as other centerlines.
Is there a way to know what type of line this is? So I can add this type into my AddIn that users can select it.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
