not able to save print to pdf file
2020mme013
2020mme013
Hi, here is my code
Dim oDoc As PartDocument
oDoc = g_inventorApplication.ActiveDocument
Dim oPath As String = System.IO.Path.GetDirectoryName(oDoc.FullDocumentName)
'-----get PDF target folder path-----
Dim oPDFFolder As String = oPath & "\" & " PDF Files"
'-----Check for the pdf folder and create it if it does not exist-----
If Not System.IO.Directory.Exists(oPDFFolder) Then
System.IO.Directory.CreateDirectory(oPDFFolder)
End If
'-----Search for idw's in folder-----
Dim MyDwgFiles As String()
MyDwgFiles = System.IO.Directory.GetFiles(oPath, "*.idw")
'-----Starts the Loop-----
For Each MyDwgFile As String In MyDwgFiles
g_inventorApplication.SilentOperation = True
Dim partDoc As DrawingDocument = g_inventorApplication.Documents.Open(MyDwgFile, False)
Dim CurrentFilename As String = System.IO.Path.GetFileNameWithoutExtension(partDoc.FullDocumentName)
'-----Filename definition-----
Dim oFileName As String = oPDFFolder & "\" & CurrentFilename & ".pdf"
'-----Publish document-----
Dim oDrgPrintMgr As Inventor.DrawingPrintManager = partDoc.PrintManager
oDrgPrintMgr.Printer = "PDFfill"
'oDoc.Interactive = False
'Dim oDrgPrintMgr As DrawingPrintManager
'oDrgPrintMgr = oDoc.PrintManager
oDrgPrintMgr.AllColorsAsBlack = True
oDrgPrintMgr.ScaleMode = Inventor.PrintScaleModeEnum.kPrintBestFitScale
oDrgPrintMgr.PaperSize = Inventor.PaperSizeEnum.kPaperSize11x17
oDrgPrintMgr.Orientation = Inventor.PrintOrientationEnum.kLandscapeOrientation
oDrgPrintMgr.ColorMode = Inventor.PrintColorModeEnum.kPrintColorPalette
oDrgPrintMgr.NumberOfCopies = 1
oDrgPrintMgr.Rotate90Degrees = False
oDrgPrintMgr.AllColorsAsBlack = False
oDrgPrintMgr.RemoveLineWeights = True
oDrgPrintMgr.TilingEnabled = False
oDrgPrintMgr.PrintToFile(oFileName)
oDrgPrintMgr.SubmitPrint()
partDoc.Close(False)
partDoc = Nothing
g_inventorApplication.SilentOperation = False
Next
g_inventorApplication.Documents.CloseAll(True)
'-----Opens PDF Folder-----
Shell("explorer.exe " & oPDFFolder, vbNormalFocus)
In the above code " oDrgPrinter.Printer = "PDFfill"" on this line I am getting the error like "System.Runtime.InteropServices.COMException: 'Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))'"
If I commented out that line then pdf file is not saving at the destination folder. If anyone has idea please solve this problem.
GosponZ
Try this one just change path. You can edit for your need
'response = MessageBox.Show("Did you change path in this rule?", "Reminder",MessageBoxButtons.YesNo)
'If response = vbNo Then Exit Sub
'iLogicVb.RunRule("SAVE PDF")
'Save PDF with options
'SaveLoc = "C:\"
'FileName = ThisDoc.FileName(True)
'ThisDoc.Document.SaveAs(FileName & (".pdf") , True)
oPath = ThisDoc.Path
PN = iProperties.Value("Project", "Part Number")
'path_and_namePDF = ThisDoc.Pathandname(False)
oFileName = ThisDoc.FileName(False) 'without extension
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 1
'oOptions.Value("Custom_End_Sheet") = 4
End If
'Set the destination file name
oPath = "c:\"
'oPath = InputBox("Replace Path","New Path")
oDataMedium.FileName = oPath & "\" & PN & ".pdf"
'Publish document
'Confirmation message
MessageBox.Show("PDF SAVED TO: " & oDataMedium.FileName, "PDF Saved", MessageBoxButtons.OK)
On Error Goto handlePDFLock
'Publish document.
Call oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Exit Sub
handlePDFLock:
MessageBox.Show("PDF could not be saved, most likely someone else has it open", "No PDF for you " & ThisApplication.GeneralOptions.UserName & "!")
Resume Next
handleXLSLock:
MessageBox.Show("No XLS", "iLogic")
Resume Next
