Saving New Part to Specified Folder
gbaker7NQNF
gbaker7NQNF
I've written this code to automatically generate parts using a spreadsheet and a parameterized model. So far it has been working well. The only problem is that parts are saved to the same folder as the model. I would like to be able to select a save folder for the new parts, similar to how the .xlxs is selected at the beginning. A small handful of people will be using this for different purposes, so unfortunately I cant send everything to a set folder.
I'm new to iLogic and honestly, coding in general (This script is a Frankenstein's monster of whatever I could find online, I'm not even completely sure what everything means...) Any help would be greatly appreciated!
Dim fd As OpenFileDialog = New OpenFileDialog()
Dim strFileName As String
fd.Title = "Select File For Data"
fd.Filter = "All Files (*.*)|*.*|All files (*.*)|*.*"
fd.FilterIndex = 2
fd.RestoreDirectory = True
If fd.ShowDialog() = DialogResult.OK Then strFileName = fd.FileName
GoExcel.Open(strFileName,"Acrylic Cutting Schedule")
If strFileName = fd.FileName
	MessageBox.Show("Excel data successfully imported!")
Else
	MessageBox.Show("Excel data import FAILED. Check File.")
Dim sFilePath As String= ThisDoc.Path & "\"
Dim sNewName As String
Dim doc As Document = ThisDoc.Document
Dim xDoc As Document
For i = 14 To qty
 sNewName = GoExcel.CellValue("B" & i)
 doc.SaveAs(sFilePath & sNewName & ".ipt", True)
 xDoc = ThisApplication.Documents.Open(sFilePath & sNewName & ".ipt")
 Dim oPars As UserParameters = xDoc.ComponentDefinition.Parameters.UserParameters
 oPars.Item("width").Expression = "isolate(" & GoExcel.CellValue("D" & i) & ";in;in)"
 oPars.Item("height").Expression = "isolate(" & GoExcel.CellValue("I" & i) & ";in;in)"
 oPars.Item("thk").Expression = "isolate(" & GoExcel.CellValue("C" & i) & ";in;in)"
 xDoc.Save
 xDoc.Close(True)
Next i
GoExcel.Close
iLogicVb.UpdateWhenDone = True
A.Acheson
Here is a handy post I found  to launch the folder dialogue for windows. You will need a different dialogue box specifically for folders.
A quick test of the sub routine to see the results
Sub Main
	AbsolutePathOfDialogBoxes()
End Sub
Private Sub AbsolutePathOfDialogBoxes()
    Dim dlgFolder = New FolderBrowserDialog
	dlgFolder.ShowDialog
    'Dim dlgOpenFile = New OpenFileDialog
    'Dim dlgSaveFile = New SaveFileDialog
    Dim absolutePath As String
    absolutePath = dlgFolder.SelectedPath
    'absolutePath = dlgOpenFile.FileName
    'absolutePath = dlgSaveFile.FileName
	MessageBox.Show(absolutePath, "absolutePath")
End Sub
Here is what you will need
'Set Root Path from where to start from
dlgFolder.SelectedPath = "C:\Temp"
Dim absolutePath As String = dlgFolder.SelectedPath
Regards
Alan
gbaker7NQNF
Thanks! That worked Great! I have one other question while I'm here. I've been trying to figure out a way to loop the part generation until the end of the list in Excel. Currently I need to tell it how long to go, but that leaves room for user error which I would like to avoid.
A.Acheson
If you  use the GoExcel.CellValues function you can return the values in a list Then you can either put that into a multivalue parameter in the document or directly to an arraylist. Once you make the row number larger than you need the arraylist will skip the blank cells and return only values. Then you can retrieve the count and your loop is then flexible.
Storage Object (Arraylist)
Dim List As New ArrayList
List = GoExcel.CellValues("LinkedParameters.xlsx", "Sheet1", "A2", "A20")
MessageBox.Show(List.Count, "Title")
 Storage Object (MultiValue Parameter)
MultiValue.List("d0") = GoExcel.CellValues("LinkedParameters.xlsx", "Sheet1", "A2", "A20")
MessageBox.Show(MultiValue.List("d0").Count, "Title")
Regards
Alan
