No Shading on PDF Exports VIA API
el_jefe_de_steak
el_jefe_de_steak
Hi, I am using the Inventor API to export PDF files of drawings that have shaded views on them. I am doing this with Inventor set to not visible (running in the background). It seems that somehow Inventor is not rendering the shading on the views properly and just exports them with no shading. Is there a way to fix this?
WCrihfield
Are you specifying anything for the"All_Color_AS_Black" option?  Have you tried it with the Inventor application being visible, to see if it makes any difference?
Wesley Crihfield
(Not an Autodesk Employee)
krosier.tx
We're having a similar problem with Inventor 2021. We use the PDF add-in SaveCopyAs method from VBA, called via OLE in a Perl script that is executed by a Scheduled Task on a dedicated Windows 10 physical host with an nvidia GPU. The shading renders correctly with Inventor's "Graphics Hardware" setting of Quality, only when the Windows user is logged in and the scheduled task executes in the foreground mode ('run whether use is logged in or not' option is disabled). In all other scenarios, the shading renders incorrectly and inconsistently with Inventor's "Graphics Hardware" setting of Quality. We still see the coloring in the PDF, but it is not in the correct places.
We are following the Export to PDF API Sample without any additional settings.
The shading is rendered correctly with Inventor is run as a background scheduled task, even with the Windows user logged out, if Inventor's "Graphics Hardware" setting is set to Performance. Since our users are creating the drawings using the Quality graphics setting, we don't think generating PDFs with the Performance graphics setting is suitable.
Annoyingly this only happens with some of our drawings with shading, and not all of them. So we are unable to reproduce it with a simple test drawing.
