New to VBA
New to VBA
Message 1 of 12
New to VBA
Hi
I have some code that looks for the Min and Max in an array and then removes the Min and Max. My array has always 4 values now what i want to do is when the Min and Max are removed from the array is to use the other 2 values in mathformulas is that possible ?
So lets say P1 is the Min and P4 is the Max so i have P3 and P2 and i want to use P3 and P2 in some mathformulas.
'create list of values
Dim MyArrayList As New ArrayList
MyArrayList.add(p1)
MyArrayList.add(p2)
MyArrayList.add(p3)
MyArrayList.add(p4)
'find mininum
oMin = MinOfMany(p1, p2, p3, p4)
'look at each item in the list and
'remove if it matches minimum
For Each oItem in MyArrayList
	If oItem = oMin Then
		MyArrayList.Remove(oItem)
		Exit For
	End If
Next
'find maximum
oMax = MaxOfMany(p1, p2, p3, p4)
'remove if it matches maximum
	If oItem = oMax Then
		Exit For
	End If
Next
'get user input
oInput = InputListBox("Choose one", MyArrayList, "", "iLogic", "Values")
If oInput = "" Then Return 'do nothing if nothing is selected
'deplay selected value
MessageBox.Show("You selected: " & oInput, "iLogic")
 thanks in advance
Replies (11)
Message 2 of 12
Owner2229
Hey, first of, this isn't VBA, it's iLogic. The language used in iLogic is VB.Net.
Here's your rule:
'Create a list of values
Dim oValues(3) As Double
oValues(0) = p1
oValues(1) = p2
oValues(2) = p3
oValues(3) = p4
'Find min and max
Dim oMin As Double = 1000000000
Dim oMax As Double = -1000000000 For Each oValue As Double In oValues If oValue < oMin Then oMin = oValue
If oValue > oMax Then oMax = oValue Next
'Remove min and max For Each oValue As Double In oValues
Try If oValue = oMin Then oValue = Nothing If oValue = oMax Then oValue = Nothing Catch
End Try Next 'Find the remaining values
Dim rValues(0) As Double
If oValue = Nothing Then Continue For
If rValues(rValues.Length - 1) <> Nothing Then
ReDim Preserve rValues(rValues.Length)
End If
rValues(rValues.Length - 1) = oValue
Next
'Sum remaining values
Dim Result As Double = 0
For Each oValue As Double In rValues
Result += oValue
Next
MsgBox(Result)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 12
Thanks for correcting me.
But your code doesn't do what i want i gives as answer -2,0.... E-14
But i want the 2 points that aren't the min max so when P1 and P4 are the min max then i want to use P2 en P3 in forumula like
Asin((((P2*-1)+P3)/R))
Message 4 of 12
Owner2229
Wait, what? So these are points, ok... You can't calculate with points like with values. Each point has at least two values (X and Y), three if it is 3d point (X, Y, Z), how would you want to calculate that?
It's quite interesting it converted them to double without any issue.
Mike
Message 5 of 12
the points i meant are values from reference parameters and it is with those values that i want to calculate
Message 6 of 12
Owner2229
This way you can calculate with the remaining values however you want:
'Calculate with remaining values
If rValues.Length < 2 Then Exit Sub
Dim R1 As Double = rValues(0)
Dim R2 As Double = rValues(1)
'Example A
Dim Result As Double = R1 + R2 MsgBox(Result)
'Example B
Dim R As Double = 10 'I don't know where you've got the R from,
'so I've declared it on my own
Result = Asin(((R1 * -1) + R2) / R)
MsgBox(Result)
Can you post the source data? Aka. the values of P1, P2, P3, P4
It might help.
Mike
Message 7 of 12
I tried you're code and modified it a bit.
SyntaxEditor Code Snippet
oValues(0) = X_Afstand_1_Ruit
oValues(1) = X_Afstand_2_Ruit
oValues(2) = X_Afstand_3_Ruit
oValues(3) = X_Afstand_4_Ruit
'Find min and max
oMin = MinOfMany(X_Afstand_1_Ruit,X_Afstand_2_Ruit,X_Afstand_3_Ruit,X_Afstand_4_Ruit)
oMax = MaxOfMany(X_Afstand_1_Ruit,X_Afstand_2_Ruit,X_Afstand_3_Ruit,X_Afstand_4_Ruit)
Next
'Remove min and max
    Try
    Catch
    End Try
Next
    End If
Next
Dim Result As Double = Nothing
    Result += oValue
Next
'MsgBox(Result)
'Example B
MsgBox(Result)
 you gave
 i used
because it has to be the Min and Max from these 4 values
 So when X_Afstand_1 is the minimum and X_Afstand_4 is the Maximum.
I want to use X_Afstand_2 and X_Afstand_3
R is a predefined parameter
Asin(((X_Afstand_2 * -1) + X_Afstand_3) / R)
When i run the code now it says NaN (not a number)
Message 8 of 12
i modiefied my code and it works until i try to use the Asin function
the Values are -28.5/28.5/-16.5/16.5 and A1=95
when i put in
Asin=((B1+H1)/A1)
I get this error : Het argument is niet opgegeven voor de parameter d van Public Shared Function Asin(d As Double) As Double
Translation: The argument is not specified for the parameter d of Public Shared Function Asin (d As Double) As Double
'Find min and max
Next
MessageBox.Show(oMin, "Title")
MessageBox.Show(oMax, "Title")
'Remove min and max
    Try
    Catch
    End Try
Next
    End If
Next
MessageBox.Show(rValues(0), "Title")
MessageBox.Show(rValues(1), "Title")
    Result += oValue
Next
'MsgBox(Result)
'Calculate with remaining values'If rValues.Length < 2 Then Exit Sub
'Dim R1 As Double = rValues(0)'Dim R2 As Double = rValues(0)
'Bereken van de hoek
A1=((Binnen_diameter_Ruit/2)+Laagdikte_Ruit)
MessageBox.Show(A1, "A1")
B1=rValues(0)*-1
MessageBox.Show(B1, "B1")
H1=rValues(1)*1
MessageBox.Show(H1, "H1")
G1=B1+H1
MessageBox.Show(G1, "G1")
I1=G1/A1
MessageBox.Show(I1, "I1")
J1=Asin(I1)*PI/180
K1=J1*PI
L1=K1/180
MessageBox.Show(J1, "Title")
Asin=((B1+H1)/A1)
MessageBox.Show(Asin=((B1+H1)/A1), "Title")
Message 9 of 12
Owner2229
How about now? I assume you want the values to always be positive numbers, so I changed your "* -1" to "Abs()". It'll do better.
'Find min and max
Dim oMin As Double = MinOfMany(X_Afstand_1_Ruit,X_Afstand_2_Ruit,X_Afstand_3_Ruit,X_Afstand_4_Ruit)
Dim oMax As Double = MaxOfMany(X_Afstand_1_Ruit,X_Afstand_2_Ruit,X_Afstand_3_Ruit,X_Afstand_4_Ruit)
'Remove min and max
    Try
    Catch
    End Try
Next
    End If
Next
'Calculate the result Dim B1 As Double = Abs(rValues(0)) Dim H1 As Double = Abs(rValues(1)) Dim A1 As Double = (Binnen_diameter_Ruit / 2) + Laagdikte_Ruit Dim G1 As Double = Asin((B1 + H1) / A1)
MessageBox.Show(G1, "Title")
Mike
Message 10 of 12
Yes it works thanks
Message 11 of 12
Is there a way to automate this code. What i mean is these values are connected to points that are denfined on a plane so when the plane moves like 1mm forward these values change. Is there a way that code loops and shows the values until that plane has traveld a certain distance ?
Message 12 of 12
I've just seen also When my part is under an angle the value of rValues(0) and rValues(1)  isn't correct, i think because my part is under an angle there no 2 negative and 2 positve values so when the code takes the min and max it cant get the correct one. If you could solve that it would be a big help! 🙂
thanks in advance
in attachement are pictures of what i mean with my part under an angle
