.Net developertools.msi install
Hubert_Los
Hubert_Los
1) I can't install developertools.msi When I try to do this, I get the error message: "Could not find any version od Microsoft Visual Studio"
I have Visual Studio 2022 and Inventor 2019
2) I thought I didn't need to install it, because  I found and opened a simple sample from: https://knowledge.autodesk.com/search-result/caas/simplecontent/content/lesson-1-the-basic-plug--E2-...
Everything works but when debugging locals tree is not the same as in VBA editor in Inventor
Same problem as in this topic:    https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/vb-net-locals/m-p/10124791#M121584
Is it normal?
bradeneuropeArthur
For which inventor version?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Hubert_Los
Inventor 2019
"I have Visual Studio 2022 and Inventor 2019"
JelteDeJong
According to this article, the developertools.msi from Inventor 2020 is only usable with Visual Studio 2017. Therefore I expect that the developertools.msi from Invent or 2019 is also only working with Visual Studio 2017.
Jelte de Jong
Blog: hjalte.nl - github.com
