Need to run an external rule for all parts of an assembly
Message 1 of 11
Hello
I am trying to add some custom iproperties to all the sheet metal parts in an assembly using an external rule.
Here's the assembly rule:
Dim aDoc As AssemblyDocument
aDoc = ThisApplication.ActiveDocument
Dim iDoc As Document
For Each iDoc In aDoc.AllReferencedDocuments
iLogicVb.RunExternalRule("Test")
 Next
 And here's the external rule:
'Assigning Sheet metal Parameters
iProperties.Value("Custom", "LENGTH") = Round(SheetMetal.FlatExtentsLength)  'LENGTH OF THE PART FOR CUTTIN LIST
iProperties.Value("Custom", "WIDTH") = Round(SheetMetal.FlatExtentsWidth)   'WIDTH OF THE PART FOR CUTTING LIST
iProperties.Value("Custom", "THICKNESS") = Thickness 'MODEL PROPERTY EQUALS TO CUSTOM IPROPERTY
iProperties.Value("Custom", "AREA") = Round((SheetMetal.FlatExtentsArea / 92903.04),2) 'AREA OF THE PART FOR CUTTING LIST IN SFT
iProperties.Value("Custom", "MATERIAL") = iProperties.Material
iLogicVb.UpdateWhenDone = True
 After running the assembly rule, there are no changes at all to any parts of the assembly. Only custom iproperties are added to assembly as 0.0
P.S I am a newbie in iLogic and wrote the codes after learning from forums. Please feel free to point out any silly mistakes.
Any help is appreciated.
kp
Replies (10)
Message 2 of 11
martin.jacko
I am not sure iLogic is the right way here.
You can do it with classic VBA script.
There is short example how to open documents with VBA.
Public Declare PtrSafe Function GetTickCount Lib "kernel32" () As Long
Sub Main()
    mlngStart = GetTickCount
    Dim oDoc As Document
    For i = 0 To 4
    ThisApplication.Documents.Open ("D:\tu\" & i & ".ipt")
    Next i
    EndTimer = (GetTickCount - mlngStart)
    MsgBox "open time  " & EndTimer
    For Each oDoc In ThisApplication.Documents
        oDoc.Close (True)
    Next oDoc
End Sub
D:\tu\ folder must contains files
0.ipt 1.ipt  ..... 5.ipt
Martin
Message 3 of 11
MechMachineMan
Your current writing of the rule doesn't know the CONTEXT that the iLogic rule is supposed to be run in, so it's currently the equivalent of saying "run the rule where it is, 100 times".
To fix that, you need to supply the iLogic Rule call with some CONTEXT (ie; the DOCUMENT the rule is supposed to effect).
    iLogicVb.RunExternalRule(iDoc, "Test")
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 11
That helped 🙂
Just one more question
What's the difference in running the external rule like:
And using automation like:
auto=iLogicVb.Automation
auto.RunExternalRule(iDoc, "Test")
Message 5 of 11
matthew.johnson200
This rule is exactly what i'm looking for also, however when i try rule this rule i get this error:
Unable to cast COM object of type 'System.__ComObject' to class type 'System.String'.
Instances of types that represent COM components cannot be cast to types that do not represent COM components; however they can be cast to interfaces as long as the underlying COM component supports QueryInterface calls for the IID of the interface.
Message 6 of 11
Hi Matthew
It's been a while since I have posted this query. I am afraid I won't be able to help you with your specific error. But, below is the code that worked for me:
ASSEMBLY RULE
If iDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
auto = iLogicVb.Automation
auto.RunExternalRule(iDoc, ”Sheet Metal Parameters”)
iDoc.Close()
Next
This rule basically identifies all the sheet metal parts in the assembly, runs an external rule named "Sheet Metal Parameters" and then closes that part document.
Hope this helps.
Kp
Message 7 of 11
matthew.johnson200
This worked great.
Thanks!
Message 8 of 11
RoyWickrama_RWEI
Thanks a lot. Found a many solutions in the forum. Was about to post in the forum for help, but finally, I found your code helping me. Thanks a lot.
auto.RunExternalRule(iDoc, "D:\Vault Workspace\Projects\ExternalRules\Rules\Test")
iDoc.Close()
Next
I need to tailor the rule for my needs, will revert to you for help.
Message 9 of 11
adrian.kostilekBVRH9
Observer
Observer
Hallo, sorry for necroing
i'm triying to use this feature too.
Our company runs inventor 2014 (this may be the problem but i'm not sure)
so in the assembly i would run this rule
'lamiere
auto.RunExternalRule(iDoc, "aggiungi regole materiali")
iDoc.Close()
'parti
If iDoc.SubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}" Then
iDoc.Close()
'prossimo file
Next
which should run the external rule "aggiungi regole materiali" on each sheetmetal and part in the assembly
here is the rule i run
' Questa regola aggiunge una regola locale per la gestione dei materiali
Dim RuleName As String = 	"Materiale"
Dim RuleText As String = 	"' Hello - This is an automatically created iLogic rule" & vbCrLf & _
							"Dim oPartDoc As Inventor.PartDocument = ThisDoc.Document" & vbCrLf & _
							"Dim mat_norm As String = oPartDoc.ActiveMaterial.Item(""physmat_Comments"").Value" & vbCrLf & _
							"Dim stringa1 as String = """"" & vbCrLf & _
							"Dim stringa2 as String = """"" & vbCrLf & _
							"Dim stringa3 as String = """"" & vbCrLf & _
							"If mat_resi=""-"" Then" & vbCrLf & _
							"stringa1="""" " & vbCrLf & _
							"Else" & vbCrLf & _
"stringa1=mat_resi" & vbCrLf & _
"End If" & vbCrLf & _
"If mat_forn=""-"" Then" & vbCrLf & _
"stringa2="""" " & vbCrLf & _
"Else" & vbCrLf & _
"stringa2="" ""&mat_forn" & vbCrLf & _
"If mat_norm=""-"" Then" & vbCrLf & _
"stringa3="""" " & vbCrLf & _
"Else" & vbCrLf & _
"stringa3="" ""&mat_norm" & vbCrLf & _
"iProperties.Value(""Custom"", ""MAT_EST"")=ThisDoc.Document.ComponentDefinition.Material.Name & stringa1 & stringa2 & stringa3"& vbCrLf & _
"'non so perché ma la regola vuole questa riga commentata in fondo"
Dim oDoc As Document = ThisApplication.ActiveEditDocument
Dim iLogicAddIn As ApplicationAddIn = ThisApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
Dim iLogic As Object = iLogicAddIn.Automation
iLogic.DeleteRule(oDoc, RuleName)
iLogic.AddRule(oDoc, RuleName, RuleText)
SharedVariable("myRuleName") = "Materiale"                  		'Nome della regola.
SharedVariable("myTrigger") = "Any Model Parameter Change"    		'Tipo di trigger, deve essere esattamente quello che viene visualizzato nella finestra gestione trigger
SharedVariable("myAction") = "Add"                      			'il codice può essere usato per "Add" o "Remove" una regola da un trigger
iLogicVb.RunExternalRule("EventTriggerSet")
SharedVariable.RemoveAll()
SharedVariable("myTrigger") = "Material Change"    					'Tipo di trigger, deve essere esattamente quello che viene visualizzato nella finestra gestione trigger
oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
oParameter=oMyParameter.AddByValue("mat_resi", "-", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("mat_forn", "-", UnitsTypeEnum.kTextUnits)
MultiValue.SetList("mat_resi", "-", "J0", "J2", "JR", "K0", "K2", "KR", "L", "L0", "L2", "LR")
Parameter("mat_resi") = "-"
MultiValue.SetList("mat_forn", "-", "+M", "+N (TD)", "+Q", "+QT (TF)", "+T")
Parameter("mat_forn") = "-"
iLogicVb.RunRule("Materiale")
if i run this one on a single part or sheetmetal it works: it creates a rule, applies it to triggers and adds 2 parameters that the new rule uses, then it runs the new rule
if i use the assembly rule this is the error i get:
System.InvalidCastException: Impossibile eseguire il cast di oggetti COM di tipo 'System.__ComObject' in tipi di interfaccia 'Inventor.PartDocument'. L'operazione non è stata completata perché la chiamata QueryInterface sul componente COM per l'interfaccia con IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' non è riuscita a causa del seguente errore: Interfaccia non supportata. (Eccezione da HRESULT: 0x80004002 (E_NOINTERFACE)).
   in LmiRuleScript.Main()
   in Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   in iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
and then for each part of the assembly it says it could not find the parameter "mat_resi" which the rule should have added.
I am grateful for all the help i can get. I'm still a newbie to ilogic and i don't understand everything i do (many things come from this forums and work, i don't question them)
Message 10 of 11
halooween123
How to add a condition that if a part already has a rule, the rule will not run with that part
Message 11 of 11
WCrihfield
Hi @halooween123.
  • Do you only want the external rule to run on parts (not on sub assemblies)?
  • Can you explain "already has a rule" in more detail?
    • A specifically named rule, or just any rule?
    • If specifically named, then what is the name of the rule that it might find in the part?
      • assume spelling and capitalization are important.
  • Can you explain "the rule will not run with that part" in more detail?
    • By "the rule", do you mean the external rule, or the internal rule found within that part?
    • So, do you mean...if the part contains (a specific / or any) internal iLogic rule, then do not run this external iLogic rule on that part?
Here is an iLogic rule example that will only process parts (not sub assemblies) being referenced by the current document, and can be used either way (any internal rules in part or specific rule in part).  Just change the rule names in Lines 3 & 4, and choose which Line (Line 8 or Line 10) should be 'commented out' and which line the rule should use.
Dim oDoc As Document = ThisDoc.Document
Dim oAuto As IiLogicAutomation = iLogicVb.Automation
Dim sExtRuleName As String = "My External Rule Name"
Dim sIntRuleName As String = "Name of Internal Rule In Part"
For Each oRefDoc As Document In oDoc.AllReferencedDocuments
	If TypeOf oRefDoc Is PartDocument Then
		'next line checks for 'any' internal iLogic rules - if any found, skip this part
'		If oAuto.Rules(oRefDoc) IsNot Nothing Then Continue For
		'next line checks for 'specific' internal iLogic rule - if found, skip this part
		If oAuto.GetRule(oRefDoc, sIntRuleName) IsNot Nothing Then Continue For
		oAuto.RunExternalRule(oRefDoc, sExtRuleName)
Next oRefDoc
oDoc.Update2(True)
PS.  If the external rule is not using the iLogic code phrase 'ThisDoc.Document' to obtain a reference to the document it should be focused on, and is using 'ThisApplication.ActiveDocument' instead, then providing the referenced document to the RunExternalRule method in Line 11 will not work properly for you, and you may need to change that phrase in your external rule.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
