Need to get correct length of the part
Message 1 of 9
I am looking for a way to change my cut length code.
Sometimes the Max length is already in the material description
example: a 2.00" x 3.00" Rectangular tube is cut at 1.25": The Max Length comes out as 3.00" when it should be 1.25"
I need to check if the Measure.ExtentsLength, Measure.ExtentsWidth, Measure.ExtentsHeight..... is already in the material description then use the one that is not in the description.
The material description is stored in iProperties.Value("Project", "Stock Number")
Here is the code I am using, any help is greatly appreciated.
oDoc = ThisDoc.Document
Dim MyArrayList As New ArrayList
'get measurements
My_x = Measure.ExtentsLength
My_y = Measure.ExtentsWidth
My_z = Measure.ExtentsHeight
'Make longest value the Length, rounded to 4 places
MaxLength = Round(MaxOfMany(My_x, My_y, My_z), 4)
Dim propertyName1 As String = "CALCLength"
 'define custom prpoerty collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
 Try
'set property value
oProp = oCustomPropertySet.Item(propertyName1)
Catch
' Assume error means not found so create it
oCustomPropertySet.Add("", propertyName1)
End Try
 'set custom property value
iProperties.Value("Custom", "CALCLength") = MaxLength
Replies (8)
Message 2 of 9
bradeneuropeArthur
How is the materialdescription defined?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
Manually typed in. Working on changing that in the future
Message 4 of 9
bradeneuropeArthur
I don't understand this then:
"I need to check if the Measure.ExtentsLength, Measure.ExtentsWidth, Measure.ExtentsHeight..... is already in the material description then use the one that is not in the description. "
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 9
because the code uses the max of all extents
Message 6 of 9
Here is an actual example
11 GA x 3.00 x 3.00 HRS TUBING
if I cut it at 2.00"
run the ilogic code. the CALCLENGTH will be 3.00" when it needs to be 2.00"
Message 7 of 9
philip1009
I think this can be done with some string operations.
Get the Material name as a string with:
SyntaxEditor Code Snippet
Dim My_Material As String = ThisDoc.Document.ComponentDefinition.Material.Name
Or If the Material name is in the Stock Number then:
Dim My_Material As String = iProperties.Value("Project", "Stock Number")
If your Material names are the same format, then you can use the Mid(My_Material,x,x) to check parts of the Material name for measurements, where the first x is the starting point of your string check, and the second x is the length to check.
For example, if your material is "Extrusion 1.500" X 2.000" then
If My_x <> Mid(My_Material, 10, 5) And My_x <> Mid(My_Material, 19, 5) Then
      Max_Length = My_x
'Do the same for other measurements with ElseIf statements.
For the first number in the Mid, the value is 10 since there are 10 characters, including spaces, before the cursor is in front of the "1.500", then the second value is 5 since there are 5 characters to check including periods.
Let me know if you need more info on string operations, they are in the snippets portion of the iLogic rule editing window.
Philip Martick
Inventor 2018 Pro, AutoCAD 2018, Autodesk Vault Basic 2018
Windows 10 Pro
2X Intel Xeon E5-2630 v4 @ 2.20GHz
16.00 GB of RAM
NVIDIA Quadro M2000
Message 8 of 9
omartin
I am assuming you have other code that will update the description after getting the max length.
Aafter you make the cut is the sketch showing from the original extrusion? maybe that is why the extent is still coming out as the original length.
Was my reply Helpful ? send a Kudos or accept as solution
Message 9 of 9
bradeneuropeArthur
If dX > dY And dX > dZ Then
'MsgBox "x"
strLENGTH = dX
If dY > dZ Then
strWIDTH = dY
strTHICKNESS = dZ
Else
strWIDTH = dZ
strTHICKNESS = dY
Catch ex As Exception
End Try
If dY > dZ And dY > dX Then
'MsgBox "y"
strLENGTH = dY
If dZ > dX Then
strWIDTH = dZ
strTHICKNESS = dX
Else
strWIDTH = dX
strTHICKNESS = dZ
If dZ > dX And dZ > dY Then
'MsgBox "z"
strLENGTH = dZ
If dX > dY Then
strWIDTH = dX
strTHICKNESS = dY
Else
strWIDTH = dY
strTHICKNESS = dX
put these into properties and you have what you need
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
