Need ilogic code to continue method from rule opened file
jeremiah_boe
jeremiah_boe
I am trying to create a rule to update all of the prior templates to the new logic capabilities but have run into a snag. I am attempting to run a rule that opens a new document, which then in turn executes an external rule within the newly opened document. I have gotten the to the point where I can open the file, but not execute the run external rule from the new opened document.
iLogicVb.RunExternalRule("Delete All Rules")
iLogicVb.RunExternalRule("Add Local Rule")
oPartDoc = ThisDoc.Document.documenttype=Inventor.DocumentTypeEnum.kPartDocumentObject
oAssyDoc = ThisDoc.Document.documenttype=Inventor.DocumentTypeEnum.kAssemblyDocumentObject
oDrawDoc = ThisDoc.Document.documenttype=Inventor.DocumentTypeEnum.kDrawingDocumentObject
Part_Trigger = "\\Innovation\CAD Styles and Materials\Part Triggers.ipt"
DWG_Trigger = "\\Innovation\CAD Styles and Materials\Drawing Triggers.idw"
If ThisDoc.Document Is ThisApplication.ActiveDocument  And oPartDoc = True Then
ThisApplication.Documents.Open(Part_Trigger)
iLogicVb.RunExternalRule("Set Rule Triggers")
ElseIf ThisDoc.Document Is ThisApplication.ActiveDocument  And oAssyDoc = True Then
ElseIf ThisDoc.Document Is ThisApplication.ActiveDocument  And oDrawDoc = True Then
ThisApplication.Documents.Open(DWG_Trigger)
jeremiah_boe
I was able to create a local rule in the opening file that ran an external rule to solve this issue. Thanks to Curtis' silent open, run rule, close code; I was able to come up with this:
'define path and name
Dim sFilePath As String
sFilePath = "\\Innovation\CAD Styles and Materials\Part Triggers.ipt"
'name of ilogic rule
Dim oRuleName As String = "Set Rule Triggers"
'open the file invisibly
oFile =  ThisApplication.Documents.Open(sFilePath, False)
'define the ilogicAutomation
Dim iLogicAuto As Object
iLogicAuto = iLogicVb.Automation
'get the rule
Dim oRule As Object
oRule = iLogicAuto.GetRule(oFile, oRuleName)
'run the rule
iLogicAuto.RunRuleDirect(oRule)
'close the file
oFile.Close
sFilePath = "\\Innovation\CAD Styles and Materials\Assy Triggers.iam"
'get the rule
Dim oRule As Object
'run the rule
'close the file
oFile.Close
sFilePath = "\\Innovation\CAD Styles and Materials\Drawing Triggers.idw"
'get the rule
Dim oRule As Object
'run the rule
'close the file
oFile.Close
chandra.shekar.g
Autodesk Support
Autodesk Support
@jeremiah_boe,
Nice to know that issue is solved. For administrative reason, please click on "Accept Solution" on respective post which is solved.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
