Filename into custom iproperty
r.munozMT3QP
r.munozMT3QP
Hello
I´m ussing Tube and Pipe assembly and i need to add a tags to all the valves, by now the way we do this is to add a custom iproperty called "TAG", publish to CC, save as custom part (pasting the P&iD tag as name, and pasting the P&iD tag again in custom iproperty "TAG".
We do this to extract the "TAG" property to our drawings for manufacture
What i´m looking for is a way to extract the Filename property and put it into my TAG property automatically, i could use Ilogic, but i have no idea how to use it, so any imput will be appreciated.
Many thanks
Rodrigo
mcgyvr
Most basic explanation is as follows.. (devil is in the details not yet described by you Smiley Wink )
In a part file that has been saved already... Open the ilogic browser (View...User Interface... Ilogic... or use the + next to the model browser to open it)
On the rules tab right click and select "Add Rule"..
Give it a name..
Paste this there and press save and run.. Then close..
An custom iprop with the name TAG and value of your filename should have been created..
'create a custom iprop called TAG and make its value the filename
iProperties.Value("Custom", "TAG") = ThisDoc.FileName(False) 'false = without extension
r.munozMT3QP
Give it a name..
Many thanks, it works perfect 😄
Its possible to make this work with the parts that are inside an a assembly?
becouse i have to make this in a valve block with around 100 valves LOL.
cshunt
You can write code to cycle through each part of an assembly but if you plan on just doing it once and adding it to the template file for new parts,
You can open the assembly, "click bill of materials" click add "customer iproperty column".
Use the drop down to add the "tag" column.
Add the part name column and copy paste the part name to the tag column... all parts with it pasted in get the "tag" iproperty added.
r.munozMT3QP
I think that the solution that you propose is similar to how we do it by now (correct me if im wrong, my english could be better XD, so maybe i missunderstood you)
Now manually copiying the TAG from the P&ID and pasting into the custom part name and filling the custom TAG iproperty that we have now, if i take the name from the filename as you suggest i will take the *.ipt extension too.
I think that the best way to make this is an assembly variation of the solution that mcgyvr gave me.
