Inventor Section Views Shown As Numerical Instead Of Letters
NachoShaw
Advisor Advisor
NachoShaw
Hi
Is there a quick way of changing the section view & detail naming from alphabetical to numerical? We use numberical and it takes ages to keep manually modifying it...
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
kelly.young
Autodesk Support
Autodesk Support
Hello @NachoShaw I don't believe there is a way to do this out of the box other than opening up the view and changing it manually the long way like you are doing.
Moving to Inventor Customization Forum to see if there is a way to achieve this with iLogic.
Please select the Accept as Solution button if a post solves your issue or answers your question.
