Attaching symbols to section lines
NachoShaw
Advisor Advisor
NachoShaw
Hey
Is there a way to attached a symbol to a section line and then get the underlying section view name? We dont use the built in section view markers and are currently using a symbol to achieve what it needs to look like (you know, an industry standard drawing view marker that has been around for years...). I havent found a way of attaching it automatically to the section view line so the symbol is the current method.
unless there is an automatic way 😉
thanks
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
mdavis22569
Can you share an example of what you're doing to do?
Mike
Mike Davis
kelly.young
Autodesk Support
Autodesk Support
Hello @NachoShaw Are you familiar with how to Define a New Sketch Symbol?
Please select the Accept as Solution button if a post solves your issue or answers your question.
NachoShaw
Hi
Sure. Please attached. I have currently set up a style that only gives me 2 termination lines for the section view each end. I place the view and then add a symbol to snap onto the point of the section view line. The sections are currently listed in alphabetical 'Section A-A' etc but we need them to be numberical 'Section 4-4' etc. Unless we can change it to bahave in a numerical way, i need to keep on using the symbols 😞
Nacho
kelly.young
Autodesk Support
Autodesk Support
Hello @NachoShaw I don't think you can make that change automatically without using iLogic, will move to post to Inventor Customization Forum for best results.
Custom/user properties in view label of drawing template/style library?
Set Your Drawing View Labels to Use the Model Part Number
ilogic code to change View Label Text
Drawings, Re-number detail & section views
CAD Studio - Inventor Tools (XTools)
