Need Help with iLogic
drafting1
drafting1
Hi I have just started to see that ilogics can make things easier.
Currently when I create a final .idw I need to manually create a PDF and DXF under a folder called PDFDXF that is found under same file location. All files are kept under Vault project.
Using naming example DD-01 revA - Part Number and current revision of part.
I have used this code to ask if PDF and DXF are needed and it creates the files under correct PDFDXF folder (using as external rule .txt and trigger when closed)
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'query user
question = MessageBox.Show("Create PDF?", "Create PDF?", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
'set condition based on answer
            If question = vbYes Then
'------start of iLogic-------
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
End If
'get PDF target folder path
oFolder = oPath & "\" & "PDFDXF"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & _
" rev" & oRevNum & ".pdf"
MessageBox.Show("PDF SAVED TO: " & oDataMedium.FileName, "PDF Saved", MessageBoxButtons.OK)
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------end of iLogic-------
Else If question = vbNo Then
End If
'query user
question = MessageBox.Show("Create DXF?", "Create DXF?", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
'get DXF target folder path
'Check for the DXF folder and create it if it does not exist
End If
 'Set the DXF target file name
" rev" & oRevNum & ".dxf"
MessageBox.Show("DXF SAVED TO: " & oDataMedium.FileName, "DXF Saved", MessageBoxButtons.OK)
'Publish document
oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End If
Is it possible to get it to check these PDF & DXF into Vault?
I have added the ilogic to our standard template but what is the best way to add it to existing drawings?
sajith_subramanian
Autodesk Support
Autodesk Support
Hi @drafting1,
To check in the PDF's / DXF's, you would have to make use of the Vault API's. The ilogic API's may not have any Vault specific functionality.
Sajith
Sajith Subramanian
Autodesk Developer Network
