Create iLogic Form with VBA or iLogic
GeorgK
Advisor Advisor
GeorgK
Hello together,
I create some iLogic rules automatically. Is there any possibility to create a iLogic form with all the rules as buttons on it with VBA or iLogic?
Thank you
Georg
Sub RuniLogicRule() RuniLogic ("Path to extrenal rule.txt") End Sub Public Sub RuniLogic(ByVal RuleName As String) Dim iLogicAuto As Object Dim invDoc As DrawingDocument Set invDoc = ThisApplication.ActiveDocument Set iLogicAuto = GetiLogicAddin(ThisApplication) If (iLogicAuto Is Nothing) Then Exit Sub iLogicAuto.RunExternalRule invDoc, RuleName End Sub Public Function GetiLogicAddin(oApplication As Inventor.Application) As Object Dim addIn As ApplicationAddIn On Error GoTo NotFound Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}") If (addIn Is Nothing) Then Exit Function addIn.Activate Set GetiLogicAddin = addIn.Automation Exit Function NotFound: End Function
This is the code to call an extrenal ilogic rule from VBA.
Create a form and for each of the buttons when clicked  call the sub which runs the relevant external ilogic rule, which can be saved in a txt document.
GeorgK
Hello Alice,
thanks for your help. But I would like to add a form with VBA or iLogic and then add the rules to the form.
Georg
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
Unfortunately, there is no API to add iLogic form.
Please post this wish list at idea station using following link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
GeorgK
Is this possible for Inventor 2019?
philip1009
Unfortunately no, there's no way to control the iLogic forms via API, if you want a more dynamic form that changes, your best choice is to make the form in Visual Studio, and then look into the Create Rule for a Dialog Wizard.  If you're trying to make a form that isn't file dependent then you can make a global form.
GeorgK
I create some iLogic rules with an add-in per model. This would be great to  that with a form.
