Need help with iLogic Rule to Rename drawing sheets. to input parameters
Need help with iLogic Rule to Rename drawing sheets. to input parameters. Can someome help me automate this? the file has 3 sheets that I want to use an input parameter thats defined earlier in the iLogic program. For some reason today I just cant figure it out????
Steve
Curtis_Waguespack
Hi steve.markle,
Here is a quick example that gets an input from the user and applies it to the name of each sheet in the drawing.
I hope this helps.
Curtis
'get input from user
Dim sInput As String
sInput = InputBox("Enter Sheet Name", "iLogic", "Page")
'iterate through the sheets
Dim oSheet As Sheet
For Each oSheet In ThisApplication.ActiveDocument.Sheets
	'rename sheets
	oSheet.Name = sInput
Next
Here's an alternate version that prompt the user for a unique name for each sheet:
'Interate through the sheets
Dim oSheet As Sheet
	'rename sheets
Next
I know this code is not right , but this is what im trying to do
'get input from userDim sInput1 As String
sInput1 = WELDMENT_PART_NUMBER
Dim sInput2 As String
sInput2 = BLADE_BLANK_NUMBER
Dim sInput3 As String
sInput3 = HUB_PART_NUMBER
'iterate through the sheetsDim oSheet As Sheet
'rename sheets    oSheet.Name = sInput1
Next osheet
    oSheet.Name = sInput2
Next osheet
    oSheet.Name = sInput3
Thanks so much for your help!!!
Steve
Curtis_Waguespack
Hi steve.markle,
There might be a more concise way to do this, but this example should work for you.
I hope this helps.
Curtis
sInput1 = "Cover Sheet"
sInput2 = "General Arangement"
sInput3 = "Details"
Dim lPos As Long
Dim lLen As Long
Dim sShName As String
Dim sShNum As String
Dim oSheet As Sheet
   lPos = InStr(oSheet.Name, ":") 'position of the colon
   lLen = Len(oSheet.Name) 'length of sheet name
   sShName = Left(oSheet.Name, lPos -1) 'string left of the colon
   sShNum = Right(oSheet.Name, lLen -lPos ) 'string right of the colon
          If sShNum = 1 Then
          ElseIf sShNum = 2 Then
          ElseIf sShNum = 3 Then
          End If
Next
EXCELLENT!!! Worked perfectly!!
Steve
EXCELLENT!!!
Worked perfectly!!
Steve
