- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to sort the dxf files exported from that rule in subfolders according to the sheetmetalstyle used in the parts file, however they all end up in an unknown style folder.
It's like the Try never happens. My parts have the SMStyle text parameter in them, they have a value, and they do not contain illegal characters for folder creation. Me and ChatGPT are at a loss here, please help. Sorry for the french parts in the code
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) - 4)
oPath = ThisDoc.Path
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oFolder = oPath & "\" & oAsmName
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Exécuter cette règle à partir d'un assemblage.", "Avertissement")
Exit Sub
End If
RUsure = MessageBox.Show ( _
"Cette règle va créer un fichier DXF pour chaque pièce de tôlerie dans l'assemblage" _
& vbLf & "Les pièces doivent être sauvegardées au préalable." _
& vbLf & "Sélectionnez un côté A si l'orientation des plis est importante" _
& vbLf & "Êtes-vous certain de vouloir créer des DXF ?" _
& vbLf & "Cela peut prendre du temps.", "Exportation DXF en masse", MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
End If
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
For Each oRefDoc In oRefDocs
iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
If(System.IO.File.Exists(iptPathName)) Then
Dim oDrawDoc As PartDocument
oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
oFileName = System.IO.Path.GetFileNameWithoutExtension(oRefDoc.DisplayName)
Dim oSheetMetalStyle As String
If TypeOf oDrawDoc.ComponentDefinition Is SheetMetalComponentDefinition Then
Try
oSheetMetalStyle = iProperties.Value(oFileName, "SMStyle")
Catch
oSheetMetalStyle = "Style de tôlerie inconnu"
End Try
Dim oSubFolder As String
oSubFolder = oFolder & "\" & oSheetMetalStyle
If Not System.IO.Directory.Exists(oSubFolder) Then
System.IO.Directory.CreateDirectory(oSubFolder)
End If
oDataMedium.FileName = oSubFolder & "\" & oFileName & ".dxf"
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDrawDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
End If
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&" &
"OuterProfileLayer=0&" &
"BendUpLayer=2&" &
"BendUpLayerColor=0;255;255&" &
"BendDownLayer=7&" &
"BendDownLayerColor=255;0;255&" &
"InteriorProfilesLayer=0&" &
"ToolCenterUpLayer=3&" &
"ToolCenterUpLayerColor=255;0;0&" &
"ArcCentersLayer=3&" &
"ArcCentersLayerColor=255;0;0&" &
"FeatureProfilesUpLayer=3&" &
"FeatureProfilesUpLayerColor=255;0;0&" &
"FeatureProfilesDownLayer=3&" &
"FeatureProfilesDownLayerColor=255;0;0&" &
"InvisibleLayers=IV_TANGENT;IV_UNCONSUMED_SKETCHES&"
oCompDef.DataIO.WriteDataToFile(sOut, oDataMedium.FileName)
oCompDef.FlatPattern.ExitEdit
End If
oDrawDoc.Close
End If
Next
