Center drawing dimension text and save drawing
Pav3L
Pav3L
I have a model of a part that has 3 size options. I want the drawing associated with this part to be automatic.
I almost got it done, but when I change the drawing view scale based on the model size, the dimension text is not centered. In another topic I found a rule that centers the dimension text, which works fine when I run it manually when the drawing is open, but when it should be automatic (run by another rule) it does not work, well the rule is executed but the text is not centered before the drawing save and close operation.
1st rule that changes the drawing view scale and then executes the second rule.
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oModelDoc As PartDocument = oDoc.ReferencedDocuments.Item(1)
Dim oDimensionA As Double = (oModelDoc.ComponentDefinition.Parameters.Item("Width").Value) * 10
Dim oScale As String
Dim oView As DrawingView
If oDimensionA = 300 Then
	oScale = "1 : 2"
ElseIf oDimensionA = 450 Then
	oScale = "1 : 2.5"
ElseIf oDimensionA = 650 Then
	oScale = "1 : 3"
For Each oView In oDoc.ActiveSheet.DrawingViews
	If oView.ScaleFromBase = False
		oView.ScaleString = oScale
Next
RuleParametersOutput()
InventorVb.DocumentUpdate()
iLogicVb.UpdateWhenDone = True
iLogicVb.RunRule("Center Dimension Text")
2nd rule "Center Dimension Text" that should center the dimension text. When I run it manually after the 1st rule the dimension text is centered, but when the rule is run automatically by the 1st rule, then the text is not centered when I open the drawing.
'Set a reference to the active sheet
Dim oSheet As Sheet
Dim oDrawingDim As DrawingDimension
'Iterate over all dimensions in the drawing and center them if they are linear or angular.
For Each oSheet In oDoc.Sheets
	For Each oDrawingDim In oSheet.DrawingDimensions
		If TypeOf oDrawingDim Is LinearGeneralDimension Or
			TypeOf oDrawingDim Is AngularGeneralDimension Then
			Call oDrawingDim.CenterText
	Next
Next
oDoc.Save
oDoc.Close
I cannot share the file for copyright reasons, but if needed I could create a sample file of something else.
Pav3L
Here is a neutral file that shows the behavior. In the model, change the "SIZE" parameter and the drawing opens and changes automatically, but the dimension text is not centered.
Curtis_Waguespack
Hi @Pav3L
You might be able to do this by changing this setting in the drawing/template.
Tools tab > Options panel > Document Settings button>Drawing tab
I hope this helps.
Curtis
Reference Link: Drawing Tab Reference (Document Settings)
Pav3L
Hi @Curtis_Waguespack
That did the trick, thanks.
