Need Help to Identify the WorkAxis of Parent Hole feature of Circular Pattern
Hi ,
Can someone help me to delete a Work Axis of a Hole which is the Parent hole of the circular pattern.
I have written to create Axis for the Parent hole feature of the circular pattern.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
Dim oWorkAxis As WorkAxis
' Get all the Circular Pattern from Part Feature.
For i = 1 To oPartDoc.ComponentDefinition.Features.CircularPatternFeatures.Count
Dim oCirPattern As CircularPatternFeature
Set oCirPattern = oPartDoc.ComponentDefinition.Features.CircularPatternFeatures.Item(i)
If oCirPattern.ParentFeatures.Item(1).Type = kHoleFeatureObject Then
'To delete if the Axis for the Parent Hole aleady exists -----------------> Need Help here to Identify the Work Axis of  the Parent Hole feature of Circular Pattern
For Each oWorkAxis In oPartDoc.ComponentDefinition.WorkAxes
If oWorkAxis.DefinitionType = kRevolvedFaceWorkAxis Then
oWorkAxis.Delete
Next
Set oWorkAxis = oPartDoc.ComponentDefinition.WorkAxes.AddByRevolvedFace(oCirPattern.ParentFeatures.Item(1).Faces.Item(1), False)
oWorkAxis.Visible = true
MsgBox "Axis Enabled for " & oCirPattern.Name & "
Next i
Thanks in Advance
Regards
Alex
bradeneuropeArthur
Replace this:
If oWorkAxis.DefinitionType = 12551 Then ' or kFixedWorkAxis
On Error Resume Next oWorkAxis.Delete End If
For me it works
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Thanks for answers. My code works. But my intension was to identify workaxis presence for Parent Hole and it exists then it must skip deletion of that particular axis.
but at the same time, if the workaxis for the occurrence of the pattern (Pattern element) exists it should delete.
Meaning i would like to keep WorkAxis only for the Parent Hole feature of the Pattern, and not its elements.
2nd point is WorkAxis other than the pattern should Not be disturbed, it may be hole (without pattern/ made of extrude) etc.
something like this;
If oWorkAxis.DrivenBy.Item(oCirPattern.ParentFeatures.Item(1).Face.Item(1)) And oWorkAxis.DefinitionType = kRevolvedFaceWorkAxis Then
MsgBox oWorkAxis.Name & " " & oWorkAxis.DefinitionType
' If oWorkAxis.DefinitionType = kRevolvedFaceWorkAxis Then
oWorkAxis.Delete
Next
Regards
Alex
bradeneuropeArthur
I have tested that and it works for me.
other workaxis keep undisturbed.
children axes of the parent (Pattern Hole) will be deleted.
only thing I had changed:
is the:
"on error"
and:
If oWorkAxis.DefinitionType = kFixedWorkAxis
Shall I resend You my code?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
The Onerror resume next helped me
bradeneuropeArthur
Good to hear it is working for you now.
Could You please mark it as solved solution for administrative reasons.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
