Need help: Odd behavior when calling a 3rd party library
dhaverstick
dhaverstick
I have an Inventor addin that I recently added some functionality to. To make some calculations that I needed to make, I referenced the MathNet.Spatial library that I downloaded as a NuGet package. The Inventor addin compiles without issue and I made sure there was a copy of the MathNet.Spatial dll in the addin installation directory. However, when I try to run the addin, I get an error telling me "Could not load file or assembly 'MathNet.Spatial, version= blah, blah, blah' or one of its dependencies. The system cannot find the file specified."
Does anyone have any ideas why this dll cannot be found/loaded?
Thanks in advance,
Darren Haverstick
Paul Mueller Company
bradeneuropeArthur
Take a look at this!
https://stackoverflow.com/questions/19273918/added-mathnet-numerics-as-reference-but-the-executable-...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
dhaverstick
As I stated in my original post, the MathNet dll files are in the same directory as my Inventor addin dll.
Darren
chandra.shekar.g
Autodesk Support
Autodesk Support
@dhaverstick,
Check the supported .net framework of MathNet.Spatial.dll with version of Inventor. Usually, if framework is not matching. This kind of error may appear.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
