Need Help, Ilogic Microsoft Access tables to list ??
willemTHLQC
willemTHLQC
Im using scripts based of this ilogic and it works great .
AddReference "System.Data"
AddReference "System.Core"
AddReference "System.Xml"
Imports System.Data.OleDb
Imports System.Data
Imports System.Xml
Sub Main()
	Dim Table_ As String = "EmployeeInfo01"
	Dim query As String = "SELECT * FROM " & Table_
	Dim MDBConnString_ As String = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=C:\Temp\EmployeeInfo.accdb;Persist Security Info=False;"
	Dim ds As New DataSet
	Dim cnn As OleDbConnection = New OleDbConnection(MDBConnString_)
	cnn.Open()
	Dim cmd As New OleDbCommand(query, cnn)
	Dim da As New OleDbDataAdapter(cmd)
	da.Fill(ds, Table_)
	cnn.Close()
	Dim t1 As DataTable = ds.Tables(Table_)
	Dim row As DataRow
	Dim Item(2) As String
	For Each row In t1.Rows
		MessageBox.Show("EID : " & row(0) & " and Employee Name : " & row(1)
	Next
End Sub
 i want to build pre select for for this.
this means that in the accdb file there are more then one  table
for example have
EmployeeInfo01
EmployeeInfo02
EmployeeInfo03
EmployeeInfo04
EmployeeInfo05
EmployeeInfo06
Employee_Tables_list.Add(??) *checks the accdb  file tables and add them to the list**
MultiValue.List("Employee_Tables") = Employee_Tables_list
does anybody know how to do this??
chandra.shekar.g
Autodesk Support
Autodesk Support
@willemTHLQC,
Try below iLogic code to get names from all tables (Assumed that employee names are extracted from 2nd column. As columns are starting from 0th column, 2nd column would becomes 1st column (row(1)) in coding).
Imports System.Data
Imports System.Xml
Imports System.Collections
Sub Main()
	Dim cnt As Integer
	cnt = 6
	Dim oList(cnt) As String
	oList(0) = "EmployeeInfo1"
	oList(1) = "EmployeeInfo2"
	oList(2) = "EmployeeInfo3"
	oList(3) = "EmployeeInfo4"
	oList(4) = "EmployeeInfo5"
	oList(5) = "EmployeeInfo6"
	Dim Employee_Tables_list As New ArrayList()
	For i = 0 To cnt -1
		Dim Table_ As String = oList(i)
		Dim MDBConnString_ As String = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=D:\Chandra\Autodesk Cases\Inventor\Sep-2019\15772811\employeeinfo\EmployeeInfo.accdb;Persist Security Info=False;"
		cnn.Open()
		da.Fill(ds,Table_)
		cnn.Close()
		Dim dt As DataTable = ds.Tables(Table_)
		Dim row As DataRow
		For Each row In dt.Rows
			Employee_Tables_list.Add (row(1))
		Next
	Next
	For Each s In Employee_Tables_list
		MessageBox.Show(s)
	Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
willemTHLQC
But this is not how i meant it.
it needs to read the accdb file and export the the current table names to a list when i add a table name in the accdb file it will be added next time when i run the script, i dont want it edit the ilogic script every time im adding a table to the file.
chandra.shekar.g
Autodesk Support
Autodesk Support
@willemTHLQC,
Finally, list of tables are added to "Employee_Tables_list" using below iLogic code.
Imports System.Data
Imports System.Xml
Sub Main()
	Dim MDBConnString_ As String = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=path of database\EmployeeInfo.accdb;Persist Security Info=False;"
	cnn.Open()
	Dim oRows() As DataRow
	oRows = cnn.GetSchema("Tables").Select("Table_Type = 'table'")
	Dim oRow As DataRow
	For Each oRow In oRows
		Employee_Tables_list.Add(oRow("TABLE_NAME"))
	Next
	cnn.Close()
		MessageBox.Show(s)
	Next
End Sub
Thanks ans regards,
CHANDRA SHEKAR G
Developer Advocate
willemTHLQC
Thank you, this works great 👍
