VBA Derive Part function failing to create new part document
Hi all,
I posted a couple weeks ago about something similar to this but didn't get an answer. Since my last post I've changed the way I get the surface body I needed so I don't need help with that anymore. However, I'm having a ton of trouble getting the derive function to work properly.
I've been using posts from mod the machine as a reference, but for some reason the exact same syntax is failing at the "Set newPart = ...." line, throwing an "Invalid procedure call or argument" error.
Every reference I've found uses this exact same syntax, so I don't know what the problem is. If anyone can help me figure this out I would appreciate it.
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim template As String
Dim folder As String
template = " "
folder = PathName(oDoc.FullFileName)
Dim partColl As ObjectCollection
Set partColl = ThisApplication.TransientObjects.CreateObjectCollection
Dim i As Integer: i = 0
Dim oSB As SurfaceBody
For Each oSB In oDoc.ComponentDefinition.SurfaceBodies
    'set new part throws invalid procedure call or argument
    Dim newPart As PartDocument
    Set newPart = ThisApplication.Documents.Add(kPartDocumentObject, template, True)
    Dim oDerPartComps As DerivedPartComponents
    Set oDerPartComps = newPart.ComponentDefinition.ReferenceComponents.DerivedPartComponents
    Dim oDerPartDef As DerivedPartUniformScaleDef
    Set oDerPartDef = oDerPartComps.CreateUniformScaleDef(oDoc.FullFileName)
' create definition corresponding to desired type of derived part
    oDerPartDef.ScaleFactor = 1
    Call oDerPartDef.ExcludeAll
    Dim oDerPartEnt As DerivedPartEntity
    For Each oDerPartEnt In oDerPartDef.Surfaces
        If oDerPartEnt.Type = kSurfaceBodiesObject Then
            oDerPartEnt.IncludeEntity = True
    Next
    Call oDerPartComps.Add(oDerPartDef)
    Call partColl.Add(newPart)
    oDerPartDef.DeriveStyle = kDeriveAsWorkSurface
    Dim oDerComp As DerivedPartComponent
    Set oDerComp = oDerPartComps.Add(oDerPartDef)
    newPart.PropertySets.Item("Inventor Summary Information").Item("Title").Value = oSB.Name
    i = i + 1
    ThisApplication.SilentOperation = True
    Call newPart.SaveAs(folder & oSB.Name & "_" & i & ".ipt", False)
    ThisApplication.SilentOperation = False
    Next oSB
End Sub
Function PathName(FullPath As String) As String
 ' return all left of last \
 PathName = Left(FullPath, InStrRev(FullPath, "\"))
End Function
dean.morrison
I tried your code for just the new part line your having trouble with..
I believe its the line
template = " "
that's causing the problem.
It does however create a new part if you remove or comment out the above line.
Hope that helps..
Dean.
That seems to have gotten it past the initial problem but now it gets stuck at the line
'oDerPartDef.DeriveStyle = kDeriveAsWorkSurface', throwing a Run-time error '-2147467259 (80004005)', Automation error, Unspecified error. Did it do the same thing for you or did it run all the way through successfully?
Quick addition to this: I tried commenting out the line I just mentioned and it ran all the way through, but my derived part doesn't have anything activated. If I edit the derived part manually I can turn on the surface bodies, which is my desired end result, but I would like to have the derived surface body be active from the get-go as this whole program will be run on assemblies and having to activate each surface body would be somewhat tedious.
HideoYamada
I don't understand what you want to do exactly, but if it is separating the solids in one part file to the part files which containing each solids, this code will work.
Sub test()
    template = ""
    Dim i As Integer
     For i = 1 To oDoc.ComponentDefinition.SurfaceBodies.Count
        Set oDerPartEnt = oDerPartDef.Solids(i)
        Set oSB = oDerPartEnt.ReferencedEntity
    Next i
End Sub
Is this code suitable for you?
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
That was exactly what I needed, thank you! I just needed to make one small change, as I am trying to derive a single surface body, where you had "Set oDerPartEnt = oDerPartDef.Solids(i)" I changed it to "....oDerPartDef.Surfaces(i)" and it works perfectly.
Again, thank you so much!
