Cutout cleanup
Cutout cleanup
Cutout cleanup
I am trying to create a SMART truck bed that is driven by a form.  I have the bed, edging, center cut out & cut out trim all work great.  But..now I have to make a cutout for out riggers and when the cut is made there are ends of the I-beam that are outside the cut area that need to be removed as well and I am not sure how to get that done.
PS
I am newish to programming in iLogic so the code is a bit spaghettied.
Code:
' ***User Parameters***
Parameter("CL_TRT_BX") = CL_TRT_BX
Parameter("TRT_BX_HEIGHT") = TRT_BX_HEIGHT
Parameter("TRT_BX_WIDTH") = TRT_BX_WIDTH
Parameter("TRTBX_WIDTH_EDGE:1", "TRT_BX_WIDTH") = TRT_BX_WIDTH + 4
Parameter("TRTBX_HEIGHT_EDGE:1", "TRT_BX_HEIGHT") = TRT_BX_HEIGHT + 4
Parameter("FL_PNL:1", "BD_LENGTH") = TRIMED_BD_LENGTH
Parameter("LNG_EDGE:1", "TOTAL_BD_LENGTH") = TOTAL_BD_LENGTH
Parameter("RR_EDGE:1", "TOTAL_BD_WIDTH") = TOTAL_BD_WIDTH
Parameter("FRNT_EDGE:1", "TOTAL_BD_WIDTH") = TOTAL_BD_WIDTH
Parameter("SRPT_TUBE2:1", "LNG_SPPRT_TUBE_LNGTH") = LNG_SPPRT_TUBE_LNGTH
NUM_CRSS_MEMBRS = Math.Round(Val(TOTAL_BD_LENGTH / 13), 0, MidpointRounding.AwayFromZero)
If TOTAL_BD_WIDTH = 102 in Then
Patterns.AddRectangular("Component Pattern 8:1", "FL_PNL:1", 13 ul,
                        8 in, "FL_PNL:1", "Edge0")
ElseIf TOTAL_BD_WIDTH > 102 in Then
Patterns.AddRectangular("Component Pattern 8:1", "FL_PNL:1", 12 ul,
'ADDING TURRETBOX CUTOUT COMPONETS   NUM_CRSS_MEMBRS
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmDoc= ThisApplication.ActiveDocument
Dim oDef As AssemblyComponentDefinition
oDef = oAsmDoc.ComponentDefinition
Dim oPat As OccurrencePattern
oPat = oDef.OccurrencePatterns.Item("FLOOR Pattern 8:1")
Dim oAssemblyFeatures As Features
oAssemblyFeatures = oDef.Features
Dim oAssemblyFeature As PartFeature
'Iterate through all of the assembly features
For Each oAssemblyFeature In oAssemblyFeatures
    If oAssemblyFeature.Name  = "TURRET BOX CUT OUT" Then
   	'look at the pattern elements
   	 Dim oPatE As OccurrencePatternElement
	For Each oPatE In oPat.OccurrencePatternElements
		'look at the pattern element contents
		Dim oOcc As ComponentOccurrence
		For Each oOcc In oPatE.Occurrences
		 'add the element contents to the feature
		 oAssemblyFeature.AddParticipant(oOcc)
		Next
	Next
Next
oPat = oDef.OccurrencePatterns.Item("BEAM Pattern 9:1")
		Next
	Next
Next
    If oAssemblyFeature.Name  = "RR MH CUTOUT" Then
		Next
	Next
Next
JamieVJohnson2
Code what the user would do.
1.   Part is too long, cutting in middle will leave ends sticking out
1a.  Use a longer cut boundary, perhaps ridiculously long to ensure nothing sticks out.
1b.  Remove faces using delete face command until all stuck out faces are gone.
1c.  Separate bodies, then delete bodies.
2.  Resize part to fit within cut boundary.
3.  Resize part to not need a cut.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
1a - If i make the cut boundary bigger then the mfgr would make it way bigger then necessary - can't do.
1b - I have never seen an example of iLogic being used to delete a face.
1c - Not sure what you mean
2 &3 - The parts are made to the manufacturers specs, any alterations would make the drawings we send them look incorrect.
JamieVJohnson2
1c.
Part document
1. Extruded box long
2. Created cut box in middle, subtracted, ended up with 2 bodies as 1 solid
3. create work plane in cut zone (anywhere should work).
4. Ran Split - selected "Split Solid", and Split Tool was work plane dividing both bodies.
5. Got 2 solid bodies.
After a bit more thought I think you were correct with point 1a & 2.  By combining those ideas I do believe that if I make the I-Beams a 1/16 shorter (which don't get dimensioned on the dwgs).  I can create a 2nd cut boundary a 1/32 smaller in the length dimension and widen it to whatever width I need to remove the excess.
