Drawing - Aligning base view with largest face landscape
NachoShaw
Advisor Advisor
NachoShaw
Hi
a while ago i wrote a method for positioning parts into my drawing that forces the base view to show the largest face and then also orients it so that its always landscape. It works well but its slow. The reason for that is the process it goes through which is-
open part visible (only works visible)
loop through the part faces checking the area and storing the value
adding the face to a selection set only if the face is larger
once the larger face is selected, use the Look At command to bring that face to the camera
add the base view as Current View
i believe it would be much faster if the opening visible process was removed but then how could i reorient the view? is it possible to do this with a matrix of some sort to get the largest face and orient it as the base view?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
HideoYamada
Does DrawingView.Camera Property help you?
I have never used Camera APIs, but I feel it is possible.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
HideoYamada
I did quick hack, but could not make change to the DrawingView.Camera.
All of the changes to the eye point that my code did were ignored.
Freeradical
 Hideo Yamada
HideoYamada
This is not a complete solution for you, but I found the way to change a DrawingView orientation and report now.
(And I hope this code helping you.)
Option Explicit
Sub FlipCameraToOppositeView()
    Dim oDrawingDoc As DrawingDocument
    Set oDrawingDoc = ThisApplication.ActiveDocument
    Dim oSourceView As DrawingView
    Set oSourceView = oDrawingDoc.ActiveSheet.DrawingViews(1)
    Dim oCamera As Camera
    Set oCamera = oSourceView.Camera
    Dim oUpVector As UnitVector
    Set oUpVector = oCamera.UpVector
    oCamera.Eye = GetOppositeEyePoint(oCamera)
    oCamera.UpVector = oUpVector
    oCamera.ApplyWithoutTransition
End Sub
Function GetOppositeEyePoint(oCamera As Camera) As Point
    Dim X As Double
    Dim Y As Double
    Dim Z As Double
    X = oCamera.Target.X * 2 - oCamera.Eye.X
    Y = oCamera.Target.Y * 2 - oCamera.Eye.Y
    Z = oCamera.Target.Z * 2 - oCamera.Eye.Z
    Set GetOppositeEyePoint = ThisApplication.TransientGeometry.CreatePoint(X, Y, Z)
End Function
This code moves the eye point to the opposite side of the target point.
Overwriting the X, Y, Z of Camera.Eye directly will be ignored as I wrote in my last post, but overwriting Eye of Camera is valid.
invalid : oCamera.Eye.X = value
valid : oCamera.Eye = oPoint
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
NachoShaw
Hi
Appreciate the time in helping me out, looks good and i will try this my project later today. It looks like i might be able to manipulate this to another feature i have been trying to work out which is
Getting the current camera from a view and applying the same view to other views as we typically have different variations of parts / assemblies but need the view direction to be the same 🙂
Thanks again
Nacho
Nacho
