Multiple Inventor Drawing Opened Files Check in
SPALANIAPPANTN47S
Message 1 of 10
SPALANIAPPANTN47S
Hi Guys,
I need to check in the multiple drawing files into vault by default macros in inventor.
For that, I tried using with the below code.
Sub CheckInMultipleOpenDrawings()
Dim oDoc As Inventor.Document
For Each oDoc In ThisApplication.Documents.VisibleDocuments
If oDoc.DocumentType <> kDrawingDocumentObject Then
GoTo NextDoc
ElseIf oDoc.DocumentType = kDrawingDocumentObject Then
oDoc.Save
Set ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop")
ControlDefinition.Execute2 (True)
oDoc.Close
End If
NextDoc:
Next
MsgBox "Checked-in the drawings"
End Sub
In that it will checking in only one or two files. Not working for all the opened drawing files.
If u have any ideas to check multiple drawing files via macro..
Please suggest..
Replies (9)
Message 2 of 10
JhoelForshav
Hi @SPALANIAPPANTN47S
Executing a controldefinition will give the same result as clicking the button in the UI manually. Therefore, the check in command will be run on the document that is active at the time when you execute the command.
I think you'll get your desired result if you make sure to activate each drawing document before executing the command (oDoc.Activate). Otherwise it's like a lottery which document will be checked in (The one that gets activated when the previously active document is closed)
Try this 🙂
GoTo NextDoc
oDoc.Activate 'Activate the drawing
oDoc.Save
oDoc.Close
End If
NextDoc:
Next
End Sub
Message 3 of 10
SPALANIAPPANTN47S
Thanks for your solution..
Its working now..
Message 4 of 10
Does not work for me, I am getting this error....
Probably something simple
Message 5 of 10
JhoelForshav
@Anonymous
This is VBA not iLogic... If you want to run it as an iLogic rule you could use something like this 🙂
For Each oDoc As Document In ThisApplication.Documents.VisibleDocuments
If oDoc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Continue For
oDoc.Save
ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop").Execute2 (True)
If oDoc IsNot ThisDoc.Document Then oDoc.Close
Next
MsgBox("Checked-in the drawings")
Message 6 of 10
SPALANIAPPANTN47S
Also need your thoughts, on how to suppress/close  the ilogic/forms pop up/dialog  box while checking in..
It comes at intermediate.
Message 7 of 10
JhoelForshav
@SPALANIAPPANTN47S
You can set options for vault dialog suppression.
Vault tab > Vault Options > Dialog Supression 🙂
Message 8 of 10
SPALANIAPPANTN47S
Suppression is available for Check in / check out dialog only.. Apart from this i need to suppress the ilogic forms dialog..
Message 9 of 10
SPALANIAPPANTN47S
For Example,
If there are 5 visible drawings, only first & last are getting checked in..
Message 10 of 10
SPALANIAPPANTN47S
Hi Jhoel,
Even after providing the code to activate the document only two files are checking in..
For example , If i opened 5 Drawings (Name : 101,102,103,104 & 105)
Only First and last are getting checked in..
Is there any solution to check in for all the visible/opened drawings.
@JhoelForshav
