multiple dwg to dxf export
hEINSTEIN
hEINSTEIN
Hello
I am facing an issue with Task Scheduler while trying to convert multiple .dwg files to .dxf. The process worked perfectly fine with TS 2022, but with TS 2023, it hangs on the progress screen, and nothing happens after that.
Do any of you have an idea of what could be causing this problem?
Alternatively, if anyone has an alternative solution for converting multiple .dwg files to .dxf.
Thank you in advance!
bradeneuropeArthur
try to create a custom task via vb.net
try to create your own add-in via vb.net
create your own app via vb.net
use ilogic from Inventor to do that
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Frederick_Law
Check the log and see which file failed.
Try migrate the files first.
I believe you're converting IV dwg and not AutoCAD dwg.
